So there is a ratio differance between the R32 gtst (4.363-1) and the gts-4 (4.375-1).this is interesting to me as I've just bought what I thought was a gtr full Diff disc to disc.As I'm dissassembling it I've noticed its a viscus diff in it witch means to me its a gts-4 diff which I bought for the bigger drive shafts (I keep braking my gtst one's )So are the half shafts inter changable between the two ?
cheers Peter
post-7066-1181723812_thumb.jpg post-7066-1181723831_thumb.jpg post-7066-1181723856_thumb.jpg post-7066-1181723876_thumb.jpg
Legend.. I can't comment on the R33 NA GTS4 diff's but the R32 GTS4 diff's are 100% mechanical. Well the one that I saw was and others have also stated they are mechanical. :)
The J30 diff runs the same pumpkin and 6bolt half shafts as a GTR/GTS4 BUT is viscous and runs a higher diff ratio. Before I bought my current mechanical I bought what was supposed to be a GTR pumpkin and axles which turned out to be a viscous unit. The dodgy jap importer *no names mentioned* sold the bits as a GTR rear end but swapped out the diff center for a cheap J30 viscous unit.
What ratio is yours? Its stamped on the crown wheel.
Hi Cubes
Still pulling it down atm only got it today ,as soon as I get it all apart I'll post up some pic's. I bought it as an 90 gtr diff complete. But the cradle is an R32 one some slight differances in the hicas setup as most parts bolt to top of diff
Cheers Peter .
A good way I test the diff is to get the car on 3 wheels leaving one of the rears up in the air (easily done if you have stiff suspension)
Then apply some torque slowly while turning the wheel, with a mechanical LSD the car should take off, a worn out diff or a vlsd would spin the lifted wheel and you will remain on the same spot.
Is that a good way of doing it guys? correct me if im wrong?
Cheers
Ric
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
