here we go..
Subs - 2 x 12 inch SONY 300XS subs in sub box. - $220
Injectors - R33 GTST standard injectors and fuel rail - $180
Gear knob - Carbon Fibre - $40
BOV - Standard MX6 bov - $5
Tyre - 1 x Standard 200SX tyre (yokohama something) - $5
Spoiler - 1 x Standard R32 GTST rear wing (Silver) - $50
Intercooler - Standard Twin Turbo Supra cooler (CORE Size - 230mm wide x 275mm high x 130mm thick) - $260
-- SOLD--GFB HYRBID bov - Unused, still in sealed box. BLUE - $200 (FIRM) -- SOLD --
Standard Turbo from RB20DET (92 R32 GTST) - Taken off car at 89,000kms. excellent condition - $300
MRT Electronic Boost controller - top of the line. LED screen, turbo timer, a/f ratio display, water spray control, and other options - $600
Location - Sydney
If you want pics, then drop your email here..
https://www.sau.com.au/forums/topic/17072-various-things-for-sale/
2 subs in the one box..
I've taken it out of my car now cause I just do not have any room with it in there.
it was ok for a while but it just got annoying cause the box would not go all the way back in the R32..
it would touch the wiper motor..
haven't you seen it?
there are a few pics in link in my signature.
  • 6 months later...
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
