I have an R200 Long nose Diff (the one with the speed sensor plug at the end)
Excellent condition, Viscous Centre that's still toight Like a toiger!!!
I run LSD's in mine and have this spare, I bought it as a daily driver then couldn't be assed putting it in...
complete diff $400 Neg.
Call me on 0405284659 for any questions
Cheers
Dave
https://www.sau.com.au/forums/topic/170833-diff/
Yeh mate, whats the ratio?
These diffs were used in some 260Zs through to R30 and Z31s, and i may be wrong but i think the IRS R31s had it too. As for flanges and the like, there are a million different combos for them, you can usually just swap your old ones into it.
https://www.sau.com.au/forums/topic/170833-diff/#findComment-3159472
Sorry I have been neglectful of the forum of late!
The diff is from a Cefiro, Not mine, I bought it as a daily driver then realised It has the long nose and Mine are all short nose... Nuts to shortening taleshafts so I am selling it.
Its 4:3 I am fairly certain, with 5 bolt outputs, I have never had it in my car, as explained above.
https://www.sau.com.au/forums/topic/170833-diff/#findComment-3181773
    • Holy hell! That is absolutely stunning! Great work!!!
