This is maybe an interesting one.. :sorcerer:
What is the formula for calculating the weight for the volume of air contained in say an 'average' 17"x 8" rim with say an 255/35R17 tyre compressed at 28psi?
Anybody?
ok, we got pV = nRT
where
p is the absolute pressure [Pa],
V is the volume [m3] of the vessel containing n\, moles of gas,
n is the amount of substance of gas [mol],
R is the gas constant [8.314 472 m3·Pa·K−1·mol−1],
T is the temperature in kelvin [K].
Now to work it out.. sau is my 'paper'
1psi = 6,894.76 pascals
p = 193,053.28 Pa @ 28psi
T = 298.15K @25degC
TBC
https://www.sau.com.au/forums/topic/170902-what-is-the-weight-of-air-in-a-tyre/
ah crud this brings painful memories of Foundation Chemistry in Uni >.<
If i studied more for that subject i could have helped you haha.
All i can tell you is;
Oxygen Standard atomic weight: 15.9994(3) g·mol−1 (grams/mol)
I think you have all the values now, just use teh formula?
Hey, to use that formula, you need your pressure to be in kPa. Not just Pa. And V needs to be in litres.
Cheers,
Adam
Year 12 Chemistry exam in two weeks time :thumbsup:
Edited by adam-__-
I reckon you could be on the mark, I still haven't got around to working it out properly, but I'm figuring it's not too much..
as air in atmosphere = 14.5psi.. .air in tyre = 28psi = 1.93 ratio x some volume equations of air in a tyre and there you go.
Just curious as to what a rim with a tyre and air weighs, compared to a bare rim weight. Silly I know.
OK yeah, it's PV = nRT.
If you use:
P = Kpa
then V = L
if you use:
P = pa
then V = cubic metres (1000L)
anyway....now that we can all sleep.......
I got 164 grams for a 235/45/17.
Assuming that "air" is 70% nitrogen and 30% oxygen.
So 1 mole of air = 28 x 0.7 + 32 x 0.3 = 29.2 g/mol
And I got the volume as 46L, at 300 kelvin and 3 atmospheres. Or ~30psi (relative)
So that gave me number of moles, n = (304 Kpa x 46L)/(8.314 x 300) = 5.6 moles.
then 5.6 moles x 29.2 g/mole = 163.5 grams
I was going to have a go at you about 30 psi being closer to 2 atmospheres, but then i remembered that 30psi tyre pressure is compared to atmospheric pressure (already 14.7psi), so yeah approx 30psi(gauge) would be about 3 atmosphere.
What I'm curious about though, is how did you calculate the volume of air?
The way I did it was, I got the area of the entire front of tyre and wheel (side facing the road), subtracted area of rims, multiplied the area calculated by width of tyre and then convert cm^3 into litres.
Hope that made sense. :)
Cheers,
Adam
Hope that made sense. :thumbsup:
Cheers,
Adam
Easy way...... pop wheel with deflated tyre on bathroom scales, note reading
inflate tyre to desired pressure, place on scales, note reading
Subtract ist reading from 2nd
I didn't do chemistry :rolleyes:
God I hate chemistry.
Anyway, density of air at, say atmospheric pressure & 50 degrees C is 1.09kg/m3.
So three bar will obvisouly be three times this.
Work out your tyre volume & you have an answer.
By the way the wheel and tyre will be on the heavier side of 20kg....
I didn't do chemistry :)
Close, but no cigar. The "deflated" tyre will still contain air at atmospheric pressure. The correct way of doing it is:
1/ Weigh tyre.
2/ Weigh wheel.
3/ Add 1 and 2 to get weight of tyre and wheel combo.
4/ Fit tyre to wheel. Inflate tyre to desired pressure. Weigh.
5/ Subtract 4 from 3 to get weight of air in tyre.
5/ Smoke cigar. Get lung cancer.
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
