mods are
r32 nissan skyline
rb20det engine
rb25det turbo running 0.85 bar
600x300x76 intercooler + piping
pod filter
greddy bov
4 inch exhast
111kw at the wheels
took the car into beyond and the car started loosing power at 4500rpm (hitting 111kw at this point then staying at that
the air and fuel ratio was at 16 (AFR:P 16) when at 4500 rpm and climbing
i was told a new fuel pump and new fuel regulator should fix the problem and the car should see 180 - 200 kw
what is your guys thoughts?
whats the cheapest fuel pump and regulator you would recommend? if i even need to do this>?
r32's don't have R&R.
if your afr is hitting 16:1, it is extremely lean and obviously not enough fuel is going through.
they are right.
a new fuel pump will probably solve the issue.
cheap option is a WALBRO 255L/h pump (yes people will say it doesn't flow enoug blah blah blah)
but it flows plenty for the 200rwkw you want to make..
it will cost about $200 - $250
next price range is a used GTR fuel pump
price will be about $250 or more.
then there are the more expensive BOSCH pump range.
then the even more expensive NIZMO range.
Don't worry too much about regulator..
if you must, NIZMO makes a direct bolt on replacement which is under $200 I think..
Might also be a good idea to replace fuel filter ($30 or so) and get your injectors ultrasonicly cleaned (not sure on price)
to get the 180+rwkw you will need some sort of tunable ecu or piggy back.
SAFC will set you back about $250 and can bent the afr enough to give you some gains.
a re-chip is even better.
to give you an idea.
way back when I had my first r32.
i had...
rb25 turbo
11psi
gtr fuel pump
side mount arc intercooler
3 inch exhaust from turbo back.
Trust panel filter in stock air box.
no ecu tuning.
it made 155rwkw.
Edited by GTST
its just hitting r&r. an engine management or a piggy back computer with a tune will fix it.
if 16:1 afr is rich, then i'd hate to see what you call lean.
bax: as GTST said, start with a new pump (and filter just to be on the safe side). that should make a world of difference.
r & r? his AFR is 16 :laughing-smiley-014:
Bax, you don't need a fuel regulator, but more likely you need a new pump. I would be worrying more about your AFR's right now than how many Kw at the wheels you are pulling as if you don't address the problems your car has you are going to be needing a new engine.
Get a confirmed diagnosis of why your AFR's are so lean before you do anything.
no couldnt see what the duty cycle , dyno didnt show that, but the guy said theres prob no point as the car wasnt recieveing enough fuel?>
im ordering a Walbro 255LPH Fuel Pump
will this do?
where does the fuel pump go in the r32 rb20det
is it easy enough to change over?
once ive changed it over do i just reset the ecu and away we go?
oh shit!
yeah i understood that wrong, too early in the morning for me.
sorry guys. that was a major brain fart.
yes walbro pump is fine.
it goes in the tank
in the boot.
under the carpet
towards the right hand side of the spare wheel
it should be pretty easy to swap.
you might need to modify the craddle a little to hold the new pump in if it is slightly different in size.
like I said before.
replace fuel filter and as well.
if you got more cash, clean injectors.
they are rated at 500hp at 14volts
do cubes volt mod for fuel pump and itll be fine and dandy, or take it somewhere for them to make sure it runs at 14.2v or watever it is constantly.
^ walbro genuine one cost me 150 to my door.. check out kudos motosport..
Hmm who says the walbro pump doesnt flow more than 200kw??
is that a fact?
nah thats BS, i have tuned cars will walbros making 50-80rwkw more than that. Cats car (300+) for example had a walbro in it before i changed it (precaution, it was two years old) to a tomei pump.
Hi all..
I had my car dynoed on Wednesday and am experiencing a similar problem.
92 R32 GTST RB20
170000km
Pod filter
3 inch split dump, 5 inch metal cat and 3 inch cat back.
R34 GTT SM intercooler
Runs about 0.75-0.8 bar (no boost controller, standard actuator.)
I got 155.1 kW at the wheels...
but my afrs were between 12.8-13.0 all they way to red line. I'll post the dyno graph later.
The workshop cleaned my AFM but it made no difference. My fuel filter is only a few months old.
Now i know its not as catastrophically as lean as 16.0:1, but is it worth starting my problem solving with a new fuel pump?
Cheers,
Rhett
Hi all..
92 R32 GTST RB20
170000km
Pod filter
Cheers,
Rhett
yours seems to be on the money 155rwkw std turbo, the gtt coolers (better than stock) have about a 2 psi drop accross them too so the turbos have to work pretty hard accross them.
Yeah I'm really happy with the result, picked up 13kW with just the cooler, with the car holding 0.75bar (11psi) all the way through to the red line. I should get a good further increase when i raise the boost to 13psi or so..
I just want to get the fuel sorted before I finally install my other goodies - Jaycar IEBC, DFA and intercooler water spray.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
