i jst got a new set of 15" retreds, and i was told that it aint a good idea to go ova 100km/h with em on....otherwise you can lose em....is it a good idea to put in new tubes or is the myth true and i shouldnt go ova 100 on a regular occasion?
DK
https://www.sau.com.au/forums/topic/170963-re-treds/
actually it's not a good idea in my book to go anything over about 40km/h. re-treads should be illegal. buy some good tyres. 15inch tyres are cheap as chips. for $500 you could get some decent tyres that will probably last 5 times your retreads and they will handle well, stop well and you'll have more fun driving.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3154818
hmm and only just then....we had retreads on the car trailer when we got it and blew all 5 within the first 3 months...bloody frustrating changing tyres all the time.
Anyway, there are cheap and OK tyres available, have a look at the "what tyres have you used" thread in here
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3157211
have u ever seen a retread?. i was considering gettin them on the bak of my 33. i got it wit 1 15 inch spare with a retread. i had no idea thats how they did them and what they looked like. they suk. u can get 80 percent brand name 15s for 30-50 dollars. even cheaper than a retread an 1 million times better.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162747
re-treads are for ..... actually im not sure what they are good for :P
My old ladys old ae82 had retreads all its life, mind you the car was a piece of shit that wouldnt die minus the fact that if you could get to 100 in it you had a down hill and a long stretch of road.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162842
Retreads are dangerous....
I remember as a young lad looking out the back window at the trailer while we were sitting on 100km/h down the freeway with a trailer on.
I saw the tread peel off and slap the guard as the tyre rotated. It took 2-3 slaps before the WHOLE guard of the trailer was removed. Amazing to watch.
Soon after that the trailer started to sway and the next thing I can remember was the arse end of the car being picked up and the rear wheels chirping as it swayed from side to side. Old man slammed the brakes and luckly we pulled up fine.
I ran a set of retreads once and had them removed as it felt as if the car was going sideways on 80km/h sweeping bends.. lol apparently it was the tread shifting on the tyres carcas. :S
Don't run them. You can pick up new tyres for cheap as these days.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162850
What I don't get is how the NSW Government can bullshyt on about trying to make the roads safer by banning P platers from driving "high performance cars" (like the entry-level Mercedes C180K, with its neck-snapping 105kW), yet its still perfectly OK for them to roll around in an old non-V8 Falcodore on retreads.
The only thing retreads are good for is paddock bashers. On a road car, they should be illegal.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162901
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
