Hi,
I know I've posted this before but things have probably changed in the past 6 months, I've had a look at this thread:
http://www.skylinesaustralia.com/forums/in...p;#entry3155248
And noticed there are some new GPS tracked alarm systems around.
I'm currently deciding whether to go with QuikTrak, or go down the route of a cheaper GPS alarm system that calls me when somethings wrong.
What GPS tracked alarm systems are around these days with the paging option?
(I'm going quiktrak if the insurance company gives me a decent discount :)).
Also if you know good Melbourne based installers to talk to about the products that would be great.
Regards,
Gareth
you can try a Python or a Viper alarms then add a gps/gsm module to the alarm. The module will sms your phone if the alarm is triggered, you can also track your car via sat. Try the Directed website.
You can also ring Zylux about the Quiktrak they can help you with it.
Mongoose sells a SMS module which hooks up to your mongoose alarm.
Although the price of alarm + mongoose sms module equals the same as quiktrack installation (although you dont pay $300 per year with pager)
http://mongoose.com.au/new-releases/mtp.php
it doesnt do a lot though. the DEI one does tracking via website for a few hundred more and you can control things on the car via SMS. I prefer these units over the mongoose one. they are also locally built. the mongoose one isn't.
Interesting, Mongoose is a well known brand but close to quiktrak price is expensive although the savings on the monitoring will be nice :cool:
Autowatch was recommended in another thread, does anyone know much about them?
I haven't heard good things about viper so far...
Do DEI have a website?
I found some results in google but I may be looking at the wrong website.
Regards,
Gareth
Hi,
Tried STI electronics but only found a soldering company.
I've found this website:
http://www.directed.com/Products/Security/Default.aspx#
DEI appears to be a group of companies marketed under multiple brand names so I'm confused what people are referring to as "DEI".
Is there a particular model?
EDIT: just read the site and looks like there is one model called the 210C in the different brands, its roughly $100/year to gets the sms's and everything. It looks like all there brands are selling the same product for GPS tracking :)
Or would you recommend the Autowatch 456 + CATE800 solution?
Regards,
Gareth
thats the US based one. its not there. give me an email addy and I'll send you the literature on it. there is a LOT of DEI gear that is made locally that is NOT listed there.
to me the DEI solution is easier to implement but the CATE is more secure. there is a newer version of it due soon that drops a few things off but fucntionality is the same.
this is the STI site for GPS position.
http://www.stitech.com.au/
I'll have these products listed on the shop site eventually (when time permits.)
  • 4 weeks later...
Sorry to drag up this old thread again, I'm pretty sure I'll be buying the Autowatch 446Premium, just wondering with the above comments when the new version of CATE was getting released?
Otherwise I'll stick with the GiSMo / Directed product that does the SMS/send/control functionality, I just need to find good installers in Victoria.
Regards,
Gareth
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
