Hey all. Well I was in an accident in January when some biatch ran into me and f'ed up my car good. Its been 4 months now without the car which sux. My panel beater takes the award for slowest c#nt out there.
Well just a few pics to show you what it looks like now.
After the accident
Pulling it apart
Getting really hacked up now.
New sections pinned in place and cut to size.
Welding started and new after market lights trial fitted.
Getting there. Just sanding and prime etc to be done.
Getting back together now.
Well just a few to give you all an idea. I will add some more as it progresses and show ya the finished product. :cool:
Edited by jrocket
https://www.sau.com.au/forums/topic/171045-my-r33-repairs/
not taking this lightly as a joke, but damn, with your accident (first pic), damn, if only the new Skyline would be similiar to a R33, with the back arse a bit pumped in towards the sides, and the lights kinda sway from the back towards the side of the back more so towards one side. looks hot. well, not like your arse after the accident but you get me.
good to hear you're slowly getting it fixed. shit happens
https://www.sau.com.au/forums/topic/171045-my-r33-repairs/#findComment-3158298
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
