HI..
Item: Stock R33 rear springs!! NOW WITH FREE rear shocks if you pick it up!! unless you pay postage. One shock is leaking a bit, the other is perfect.. Still usable!!
Condition: Excellent..
PRICE: $50
Extra info: Not to sure if you can use rear for fronts or vice versa..
Pics:
Please pm or msg here if you need anymore ifo
Cheers
Sidd.
Edited by siddr20
https://www.sau.com.au/forums/topic/171048-stock-r33-springs-pair/
Sorry, shipping will be a bit, coz of its size and weight.
40 Plus postage :) is what i wil be lookin for.
Or lowest will be 40 pick up!!
Let me know!!
Going to go get the pics now
Sidd.
  • 3 weeks later...
hey bro im interseted!
what shock is leaking?
whats the best u can do on the springs and the left shocker??
wich one is leaking, they can both be universal for each side??
whats the best u can do sent to melb?
ill take in a week depending on price
Hey champ
So sorry i didnt check this thread..
My mistake..
ok, one of the shocks is leaking (the right hand side).. Its not that bad to be honest. I was driving around on it for some time, and i seriously didnt notice any knocks etc or saging..
I will take some better pics of it when i get back from work.
Postage is about 35 bucks to melb.. Via bus freight who i normally use.
Just the springs - postage is 15 bucks.
2 shocks Plus 2 springs weigh about 15 kgs..
Let me know if you still keen
cheers
Edited by siddr20
  • 1 month later...
  • 4 weeks later...
  • 7 months later...
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
