each has their place in the car performance world
there is no such thing as " no lag " and " 0 rpm lag" its a load of rubbish
each has lag and takes time before the compressor is efficient
Thats untrue - positive displacement supercharges have zero lag they run a bypass vavle so that there is little/no flow throught the charger. As soon as the bypass vavle is closed you have boost. Also it is possilbe to control boost on most posivite displacement chargers as manufactures generally run a double sided vacuum actuator - so all you need to do is remove or apply pressure to vary the amount of air that is bypass from the compressor. We often do this on the VS-VT V6 superchargers.
The biggest compliment to the FSI engine is that it is direct injection so that higher compression ratio's can be used as chamber quenching is optimised. Another neat idea is the clutched supercharger as this will reduced the forces required to drive the charger once the turbo is brought into action.
To me the best thing nissan could do would be to introduce direct injection, crank the compression ratio up to 10:1 and add varaible cam timing.
...did anyone catch the episode of Top Gear where some mensa woman was doing the "Star in a reasonably priced car" bit and she asked Jeremy what the difference was between a turbo and a supercharger, and he had no idea?
For a guy who gets to drive some beautiful cars, and has done so for decades, he really is clueless.
Useless twat, bring back the TIFF!!!
I believe that is exactly the technology they introduced with the VQ25 engine series. Naturally aspirated compression is somewhere up around 11:1 and it's reputedly a pretty good bit of gear - for the power it is producing.
I would then add 15Psi of boost pressure on top of that. That way you can produce lots of drivable toque plus top end - you also gains lots of response.
Also has anybody seen nissan's new variable vavle control - what a bucket of shite. You cant help but think it was designed by the law department in order to get around current patents!!!!
Just as an aside, the GM diesel trucks [dirty GM's they are called], run a supercharger and turbocharger together. They are a V6 and make as much power with this setup as much bigger motors. Oh and they are two stroke deisels as well. Downside is they do like a drink!!!!!
PS They have been around for a long time, +30 years, I'll do a search and confirm when they first came out to confirm that, but I drove one at least 30 years ago [there goes my age now].
Some of you guys have a lot to learn. Others are getting there, very few actually know what they're talking about.
Go build a twincharged engine - ask lots of questions and learn as much as you can along the way. That's what I did, and the result is quite simply spectacular. It really is the best of all worlds. Snappy transient boost response at ANY RPM (even at 1000rpm you can have positive manifold pressure), good fuel consumption (for a 400hp car), giant midrange torque with NO compromise to top-end power (235rwkw from a stock-cammed RB25/30 on 9psi) and a much safer engine compared to a turbocharged-only setup because it runs so far from the detonation threshold. During valve overlap, if you have more pressure in the inlet tract than in the exhaust manifold, you get positive pressure sweeping the chamber clean of incredibly hot exhaust gas residuals - hence a cleaner, significantly colder charge. More power, less chance of detonation, more efficient engine.
Comparing superchargers to turbochargers and asking which is better is a bit like asking whether an apple is better than an orange. At what? When? On which engine? For what purpose? Which supercharger type? Which turbocharger? The list goes on.
If I had to choose between a street 500hp RB26 running an Opcon twin screw blower and a 500hp RB25 running turbochargers, I'd choose the supercharged one. If the car's purpose was drag racing, i'd go the turbo and run a giant stall convertor because top-end power is all that really matters for a drag car.
Essentially the "debate" boils down to three simple words;
Horse For Courses.
Although, some manufacturers, eg Porche, are finding ways to minimise it a lot. I have recently driven a new Hyundai Santa Fe turbo diesel and you can hear the turbo spooling up even when you only just holding your foot on the throttle at 900rpm constant. It's bloody amazing, honest you can hear the whistle it makes at 900RPM!!!
This is due to their new VGT's(Variable Geometry Turbo). Works something along the lines of changing the diameter of the exhaust turbine using a vacuum actuator, so that at low engine speeds it is the right size to boost and at high engine speeds it changes to stay efficient and increase flow.
I don't think it is that new though, Porche have been using it for some time.
Most diesels dont run a throttle's that's why you can hear the turbo spool at idle as there is either boost or atmoshpeheric pressure. And yes I am aware that some modern diesels run electronic throttles. The new triton even has stepper motor control varaible vane turbo.
    • I'm late to the party on this one but good to see common sense has prevailed and the turbo kit is coming.
    • She's looking good Greg. Colour suits it perfectly 馃憤
    • I had a look at the FAB9 EFR kit, around $8500 AU before delivery, so add in shipping, installation, consumables and tuning, I believe the price difference would be negligible  And whilst I am paying top dollar at MX5 Mania, if I have any issues with the kit they are local for support,  and from my experience, will happily go out of their way to help, hell, I've purchased parts from them and asked "how do I install or remove parts" and they have fitted a few of them for free, this means more to me than saving a few thousand dollars And yes, 99% of the time I just plod around in the car, that may change once I start hearing turbo whooshy noises, but, as I have 3 family members is the constabulary, even when I'm up it, it is only up to the speed limit, or occasionally, but rarely, overtaking on the Hwy (I just plod in the left lane typically and enjoy the drive) Plus the kids would never let it go if I got booked speeding, Jackie is constantly getting critiqued by the kids about her driving, which I think is hilarious, and tell them that she is "bringing shame to our family", so heaven forbid if I ever got done speeding, after all my mouthing off about her driving, I would never live it down, and it would be another thing she would bring up any chance she got Like the time I got drunk about 15 years ago and fell out of a cab, which gets brought up at least a few times every year since it happened Good times
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
