each has their place in the car performance world
there is no such thing as " no lag " and " 0 rpm lag" its a load of rubbish
each has lag and takes time before the compressor is efficient
Thats untrue - positive displacement supercharges have zero lag they run a bypass vavle so that there is little/no flow throught the charger. As soon as the bypass vavle is closed you have boost. Also it is possilbe to control boost on most posivite displacement chargers as manufactures generally run a double sided vacuum actuator - so all you need to do is remove or apply pressure to vary the amount of air that is bypass from the compressor. We often do this on the VS-VT V6 superchargers.
The biggest compliment to the FSI engine is that it is direct injection so that higher compression ratio's can be used as chamber quenching is optimised. Another neat idea is the clutched supercharger as this will reduced the forces required to drive the charger once the turbo is brought into action.
To me the best thing nissan could do would be to introduce direct injection, crank the compression ratio up to 10:1 and add varaible cam timing.
...did anyone catch the episode of Top Gear where some mensa woman was doing the "Star in a reasonably priced car" bit and she asked Jeremy what the difference was between a turbo and a supercharger, and he had no idea?
For a guy who gets to drive some beautiful cars, and has done so for decades, he really is clueless.
Useless twat, bring back the TIFF!!!
I believe that is exactly the technology they introduced with the VQ25 engine series. Naturally aspirated compression is somewhere up around 11:1 and it's reputedly a pretty good bit of gear - for the power it is producing.
I would then add 15Psi of boost pressure on top of that. That way you can produce lots of drivable toque plus top end - you also gains lots of response.
Also has anybody seen nissan's new variable vavle control - what a bucket of shite. You cant help but think it was designed by the law department in order to get around current patents!!!!
Just as an aside, the GM diesel trucks [dirty GM's they are called], run a supercharger and turbocharger together. They are a V6 and make as much power with this setup as much bigger motors. Oh and they are two stroke deisels as well. Downside is they do like a drink!!!!!
PS They have been around for a long time, +30 years, I'll do a search and confirm when they first came out to confirm that, but I drove one at least 30 years ago [there goes my age now].
Some of you guys have a lot to learn. Others are getting there, very few actually know what they're talking about.
Go build a twincharged engine - ask lots of questions and learn as much as you can along the way. That's what I did, and the result is quite simply spectacular. It really is the best of all worlds. Snappy transient boost response at ANY RPM (even at 1000rpm you can have positive manifold pressure), good fuel consumption (for a 400hp car), giant midrange torque with NO compromise to top-end power (235rwkw from a stock-cammed RB25/30 on 9psi) and a much safer engine compared to a turbocharged-only setup because it runs so far from the detonation threshold. During valve overlap, if you have more pressure in the inlet tract than in the exhaust manifold, you get positive pressure sweeping the chamber clean of incredibly hot exhaust gas residuals - hence a cleaner, significantly colder charge. More power, less chance of detonation, more efficient engine.
Comparing superchargers to turbochargers and asking which is better is a bit like asking whether an apple is better than an orange. At what? When? On which engine? For what purpose? Which supercharger type? Which turbocharger? The list goes on.
If I had to choose between a street 500hp RB26 running an Opcon twin screw blower and a 500hp RB25 running turbochargers, I'd choose the supercharged one. If the car's purpose was drag racing, i'd go the turbo and run a giant stall convertor because top-end power is all that really matters for a drag car.
Essentially the "debate" boils down to three simple words;
Horse For Courses.
Although, some manufacturers, eg Porche, are finding ways to minimise it a lot. I have recently driven a new Hyundai Santa Fe turbo diesel and you can hear the turbo spooling up even when you only just holding your foot on the throttle at 900rpm constant. It's bloody amazing, honest you can hear the whistle it makes at 900RPM!!!
This is due to their new VGT's(Variable Geometry Turbo). Works something along the lines of changing the diameter of the exhaust turbine using a vacuum actuator, so that at low engine speeds it is the right size to boost and at high engine speeds it changes to stay efficient and increase flow.
I don't think it is that new though, Porche have been using it for some time.
Most diesels dont run a throttle's that's why you can hear the turbo spool at idle as there is either boost or atmoshpeheric pressure. And yes I am aware that some modern diesels run electronic throttles. The new triton even has stepper motor control varaible vane turbo.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
