  • Replies 233
Hey Guys.
R32 GTS-T People REJOICE! I've sourced the rubber inlet pipe which I needed to get your silicone ones made.
So, YES I am offering the R32 GTS-T pipes!
BASS OUT
Hey ppls,
My hunt for a replacement for the standard 'sucky closed under boost" inlet pipe has never really ended, even after I gave up on the super difficult steel version I spent a lot of time on.
I've seen some which cost people $450+, I've seen others that require modifications to the standard BOV return and PCV vent hardware or pipes.
So I recently came across a a direct replacement for the standard corrugated rubber pipe in Blue Silicone! They are Hong Kong Manufactured (but isn't everyting these days) and are quite reasonably priced.
As you can see in the below pics, the pipes are a DIRECT replacement for the stock pipes but don't feature the ugly corrugations that are no good for airflow and these shouldn't suck closed due to there stronger wrapped silicone construction.
No additional hardware is required, even the standard clamps can be reused I believe.
Freight rate will be calculated on a 3kg Post Satchel with Austpost and will cost $20.
Pricing is as follows.
Inlet pipe $ 135 each
Radiator pipes $ 110 per pair
So, who is interested in these cool new items?
R32 GTS-T
1 Haysey.............Black
2 lach 32.............Black
3 SNISMO............Black
4
5
6
7
8
9
10
R33 GTS-T
1 MANWHORE..........Black
2 SoFly...................Black
3 Govich.................Black
4 RSTME.................Black
5 jeffworld2.............
6 wolverine.............Black............................PAID
7 tuitahi..................Black
8 Zilch*..................Blue
9 (B1) Mr Fanny.......
10 dOOdz.................Black
11 johnnilicte............Black
12 russo1.................Black
13 Gtshortie..............Black
14 r33_nikolas...........
15 siddr20.................Black
16 Race__24.............Black
17 Basti....................Black
18 oosx....................Black
19 Taxi33..................Black
20 Darrinspencer.......Blue
21 Fry_33..................Black
22 Shano3000............Black
23 R33Driftr...............Black.......Black
24 frx026...................Black
25 beastien................Blue
26 FLYSLY..................Blue
27 WogsRus...............Blue........Blue
28
29
30
R34 GTT
1 Bass Junky..............Black.......Black
2 Wolverine................Black
3 Black_Widow R34.....Black
4 J34..........................Black
5 so_tred....................Black
6 Haines.....................Black
7 Darrinspencer..........Blue
8 Brycey.....................Black
9
10
BASS OUT
G`DAY bass IAM IN STAGEA S2 BLUE PLEASE will deposit fund thursday.chuckie
Hey bass i pmed you a few days ago but didnt get one back. I am extremly interested in geting one of these in Black for an R32 GTS-T. if you could update me that would be great , cheers Tim
Hi matie, i will be buing just the intake pipe not the rad hoses aswell.
When this group buy finishes will there be another one, i am just going through setelment of my house and money is coming and going avery week.
Thanks
Bass,is there much difference between the r32 intake pipe and the r33 intake pipe
as i want a black one for my r32 which has a rb25 turbo on it.
which pipe will i need?
i run stock airbox,afm & bov
cheers
hiya bass please put me down for a black intake pipe to suit a series 2 stagea.
will deposit coin into bank on friday and let you know details etc friday arvo.
(lets just hope this buy goes a bit smoother than last one eh?)
cheers oxford
RSTME
the R32 GTS-T Version will be for you then.
The location of the RB25 turbo in relation to the RB20 engine will be exactly the same.
The difference is more at the other end.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
