The following people are the first lucky contestants to have their cool blue silicone inlet pipes shipped!
SydneyKid. Gary always gets priority as he's an SAU god.
R33Driftr
Beastien
Skyhy
Darrinspencer
Chuckie
Keep an eye out for an Australia Post 3kg airbag.
I reckon you'll all get them either Monday or Tuesday depending on location.
BASS OUT
GREAT WORK BASS got mine this morning look`s good ,thank`s bass,,chuckie
  • Replies 233
Darren I'm looking forward to your thoughts.
She should fit like a charm.
Ok, I fitted mine last night
My car is a series 2 Stagea with a Neo Rb25det and factory airbox.
I have a Apexi turbo, but it is a direct factory replacement, so everything should line up the same.
I had to trim the BOV return line spigots approx 15-20mm and the outlet end onto the turbo approx 15mm to get things to line up. I trimmed the BOV return spigot to the minimum lenght to just enough to get the clamp on.
I have not finish fitting the airbox/airflow meter yet, but had a quick trial fit. The inlet end will need trimming approx 15-25mm aswell.
The extra length is easily trimmed with a sharp packing knife and gives the flexibilty of it fitting to all cars.
Only took 10-15 minutes to trim and work out what was needed.
Overall. I am very happy with the finished product
Well done Bass, thanks.
well when i Put my 3037 on ill need bigger hole at the turbo end just wondering if they can make them with the bigger intake holes
I cant remember the size but I think it has 4" intake on them
Hey guys.
Unfortunately I've just received word that the factory is very busy and that the rest of the pipes wont leave for another 7-10 days.
Sorry to be a pain in the arse. With a fast start I was expecting a shipment to leave today or Monday, but my guy has informed me that they are running late.
I'll keep you updated as I go.
Cheers
BASS OUT
Oh, and for those who have already received theirs, can you please give me trader ratings?
I've just discovered that they is a 'Top 15 rated members on SAU" and I'm only a few ratings away!!!!
I WANT ON THAT LIST!!!! :laugh:
Fitted mine just now, required a bit of trimming on all ends but easy to do.
Fits well, I'm very happy with it.
Cheers again Bass
Hey Pete, When you expected to be done?
Because if they are done before the 25th of Aug, Maybe you could give mine and maybe Haysey's at DECA? Saves on shipping :huh:
Yo bass,
When should we be expecting the pipes.... I just remembered about it just today.. totally forgot that I bought one of these pipes LOL
Yeah an update would be great, also some feedback on them if any one else has put theres in would'nt go astray.
There are 2 feedbacks on fitment, just have a look above
Thanks.
Hi Guys,
Sorry I havent replied sooner, I've been flat out.
The pipes should leave OS in a couple of days, and, customs dependant, I should have them a few days after that.
I reckon you might be lucky enough to have them around next weekend if all goes to plan. :(
Cheers
BASS OUT
Because if they are done before the 25th of Aug, Maybe you could give mine and maybe Haysey's at DECA? Saves on shipping :(
shuddup vic ive already paid for my shipping hahahahahahahaha
next week sounds good to me! thanks bass!
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
