  • Replies 233
quick question..
How hot would this pipe get? Or will the pipe remain a bit cooler than stock piping?
and what did you mean by : 'sucky closed under boost' lol..
thanks
Edited by siddr20
Hey ppls,
I've checked about the logos, and unfortunately I have to order over $10,000 USD in order to have different logos. Just quietly, I'm not ordering anywhere near that!
When can you tell? Well, about 1 bar with the stock airbox and the thing will suck closed. The hotter the engine bay gets, the less boost required to suck closed. How can you tell? Well, you come up on boost and then suddenly you loose power. HPI saw it in their Project 34 and several others have seen it too.
Also the standard pipe is pretty ordinary with air flow, so the new pipe is much smoother on the inside.
BASS OUT
PS. I will get all final details of the buy together and start this running now.
Okay,
Group buy in motion.
I'll close the group buy in 2 weeks from today, so Monday week.
Payments will be as follows.
$135 per Inlet pipe. $20 per postage as it's going to be over 1kg per piece when packed. As always when sending, if you are in a remote area then the freight will be more and I will let you know and we will work it out. This has only happened twice though,
$110 for the pair of Radiator hoses also. Freight will be the same $20 for the Radiator Pipes. I might be able to combine these, but it will depend on the boxes I can get.
So it's $155 total for the inlet pipe and $135 radiator pipe.
Each pipe or hose will be in it's own card-board box and wrapped appropriately for postage.
Estimated time frame.
The supplier has told me 2-3 weeks for manufacture.
Will be about 2 weeks in freight.
Another week for me to box them up and send them out.
Okay, colours.
We can get Black, Red or Blue.
AT THIS STAGE R32 GTS-T ARE NOT BEING OFFERED UNTIL I CAN GET A STANDARD R32 GTS-T PIPE TO TEST... PLEASE LET ME KNOW IF YOU HAVE ONE OF THESE AVAILABLE.
All pipes can use the standard clamps.
Payment Details
Peter N Blythe
Bank of Melbourne, Westpac
BSB: 733382
ACC: 586817
Amount $varies
Reference : Username
Once you have paid please send me an e-mail to [email protected]
The e-mail should contain the following information.
First Name, Surname
St Address
Suburb, State, postcode
Mobile Number
Copy of deposit reference.
The package goes normal freight and so the delivery address should be somewhere that you will be during the day over the next 2-4 days depending on your location. I have had them arrive overnight, I have also had them arrive 6-7 days later (Perth and Darwin)
So, you have 2 weeks to get the payments through and leave the rest to me.
Many of you have dealt with me in the past, but for those who haven't, check my trader ratings. I'm legit.
So guys lets get it happening, I'm pretty keen on getting these myself!!!! :)
BASS OUT
Edited by Bass Junky
Bass, silly question (not doubting you in anyway and still interested) is that $30 postage for each one from hong kong to us? or are they coming over in a batch and then $30 from your house to mine?
I'm pretty tight on cash, and 30 from melbourne to sydney for 1kg seems a bit dear with normal aust post?
No harm intended, just wondering
Edited by MANWHORE
Hi Manwhore.
That's a fair question so I'll explain.
The $30 is the inside Australia freight cost.
I buy custom made boxes to the correct size for the application which cost about $5 each. The pipes will be over 1kg in weight, so the Aust Post component must be worked out on cubic volume.
I reckon the box is going to have to be about 400mm x 200mm x 200mm which which postcode 3175 to lets say 2100 = $9.65 which means that I've stuffed up the calculations terribly.
In actual fact, these things should comfortably fit into a 3kg Postage satchel!
Therefore, postage will be $20 everyone!
Sorry for the mistake! Please change the postage cost to $20. This will cover the satchel and all the stuffing around.
CHEERS PETE! (Thanks Manwhore. You have actually made my job a lot easier!)
Guest
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
