  • Replies 233
Hey Guys.
R32 GTS-T People REJOICE! I've sourced the rubber inlet pipe which I needed to get your silicone ones made.
So, YES I am offering the R32 GTS-T pipes!
BASS OUT
Hey ppls,
My hunt for a replacement for the standard 'sucky closed under boost" inlet pipe has never really ended, even after I gave up on the super difficult steel version I spent a lot of time on.
I've seen some which cost people $450+, I've seen others that require modifications to the standard BOV return and PCV vent hardware or pipes.
So I recently came across a a direct replacement for the standard corrugated rubber pipe in Blue Silicone! They are Hong Kong Manufactured (but isn't everyting these days) and are quite reasonably priced.
As you can see in the below pics, the pipes are a DIRECT replacement for the stock pipes but don't feature the ugly corrugations that are no good for airflow and these shouldn't suck closed due to there stronger wrapped silicone construction.
No additional hardware is required, even the standard clamps can be reused I believe.
Freight rate will be calculated on a 3kg Post Satchel with Austpost and will cost $20.
Pricing is as follows.
Inlet pipe $ 135 each
Radiator pipes $ 110 per pair
So, who is interested in these cool new items?
R32 GTS-T
1 Haysey.............Black
2 lach 32.............Black
3 SNISMO............Black
4
5
6
7
8
9
10
R33 GTS-T
1 MANWHORE..........Black
2 SoFly...................Black
3 Govich.................Black
4 RSTME.................Black
5 jeffworld2.............
6 wolverine.............Black............................PAID
7 tuitahi..................Black
8 Zilch*..................Blue
9 (B1) Mr Fanny.......
10 dOOdz.................Black
11 johnnilicte............Black
12 russo1.................Black
13 Gtshortie..............Black
14 r33_nikolas...........
15 siddr20.................Black
16 Race__24.............Black
17 Basti....................Black
18 oosx....................Black
19 Taxi33..................Black
20 Darrinspencer.......Blue
21 Fry_33..................Black
22 Shano3000............Black
23 R33Driftr...............Black.......Black
24 frx026...................Black
25 beastien................Blue
26 FLYSLY..................Blue
27 WogsRus...............Blue........Blue
28
29
30
R34 GTT
1 Bass Junky..............Black.......Black
2 Wolverine................Black
3 Black_Widow R34.....Black
4 J34..........................Black
5 so_tred....................Black
6 Haines.....................Black
7 Darrinspencer..........Blue
8 Brycey.....................Black
9
10
BASS OUT
G`DAY bass IAM IN STAGEA S2 BLUE PLEASE will deposit fund thursday.chuckie
Hey bass i pmed you a few days ago but didnt get one back. I am extremly interested in geting one of these in Black for an R32 GTS-T. if you could update me that would be great , cheers Tim
Hi matie, i will be buing just the intake pipe not the rad hoses aswell.
When this group buy finishes will there be another one, i am just going through setelment of my house and money is coming and going avery week.
Thanks
Bass,is there much difference between the r32 intake pipe and the r33 intake pipe
as i want a black one for my r32 which has a rb25 turbo on it.
which pipe will i need?
i run stock airbox,afm & bov
cheers
hiya bass please put me down for a black intake pipe to suit a series 2 stagea.
will deposit coin into bank on friday and let you know details etc friday arvo.
(lets just hope this buy goes a bit smoother than last one eh?)
cheers oxford
RSTME
the R32 GTS-T Version will be for you then.
The location of the RB25 turbo in relation to the RB20 engine will be exactly the same.
The difference is more at the other end.
Guest
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
