  • Replies 64
Posted Images
Thanks for the comment Guys... :thumbsup:
The Ganador Mirror is nice, but then everyone has it. So I took the Mine's Mirror because they are the ONLY company with REAL Carbon Fiber.. The Ganador mirror is painted carbon, and I am not going to pay all that money for a Carbon LOOK mirror. :nyaanyaa:
This is the full list, I am sure I miss something in there. :action-smiley-069:
Power: 520 bhp at Hub @ 7500rpm (1.3bar) Dyna-Pack Proven (590bhp @ flywheel)
Expected: 650 flywheel bhp @ 1.6bar (waiting for a re-map)
Engine: RB26DETT
HKS 88mm forge pistons
HKS H-Section Con Rods
HKS 1.2mm Metal Head Gasket
HKS T04R Stainless Steel Manifold
HKS T45S Turbo (Same as Garrett TA45S)
HKS 200mm Air Filter with Red Element
Billion Heat Reflective Wrap
HKS Polished Hard Pipe Kit
HKS Type-R Front Mount Intercooler
HKS 272 Step1 Camshaft (In/Ex)
HRD Cold Forge Adjustable CAM Pulleys
HKS External Wastegate with Screamer Pipe
Greddy Type R Blow Off valve
HKS 75mm Downpipe
Custom Made 75mm-90mm Decat Pipe
Custom Made 90mm Straight Exhaust (No Centre Silencer)
Apexi Titanium Slide Finisher
Apexi Active Tail Silencer
KYB Dual Entry Fuel Rail with Earl Braided Steel Line
HKS 6x 680cc injectors
HKS 280lph Fuel Pump
HKS F-Con V-Pro
Blitz SBC-ID III Controller
Blitz R-Vit monitor
Apexi RSM
Greddy Oil Pump
Trust Sump Extension
Grex Oil Cooler with Remote Oil Filter Relocation
Splitfire Direct Ignition Coil pack
Splitfire Direct Ignition Bridge
Impulse Performance Uprated Aluminium Radiator
Tomei Engine Oil Cap
Nismo High Pressure Radiator Cap
Stainless Steel Oil Breather Tank with Braided Line
Pivot Blue Raizin Grounding Kit with Voltage
Stabilizer
Transmission
OS Giken Uprated 1, 2, 3 gear set
HKS Twin Plate Clutch
C's Short Shifter
Nismo 2-Way LSD
Chassis
D2 Racing RS Pro Coilover Suspension with Remote Gas Reservoir (Separated Compression and Rebounce Adjustment)
D2 Racing Rear Camber Arm
Tein Front Traction Rod
D2 Racing 8 Pistons Front Brake with 356mm 2-piece Brake Disk
D2 Racing 6 Pistons Rear Brake with 356mm 2-piece Brake Disk
D2 Racing Stainless Steel Braided Brake Line
Nismo Master Cylinder Stopper
Nismo Front Strut Brace
Cusco Rear Strut Brace
Do-Luck Rear Cross Bar
HRD HICAS Cancel Bar
Asso Interspeed Centerlock Wheel (limited production of 100 sets)
Bridgestone Potenza RE050A (265/35/18)
Exterior:
TBO Front Bumper
TBO Side Skirt
Do-Luck Rear Bumper
D-Speed Front Grill
D-Speed Rear Wing
Yanack GT Front Wing
Yanack GT Rear Wing
Mine's Dry Carbon Wing Mirror
R32 N1 Headlight
Econ H4 Hi/Lo HID Kit
D-Speed Smoke Corner Lenses
Speed-R Carbon Fibre Bonnet
ARC Titanium Cooling Panel
Top Secret AeroCatch Bonnet Pin
R32 LED Rear Tail light
Tomei Rear Tail Light Cover
Window out Repaint in Lamborghini Grigio Avalon
Interior:
NISMO Sport Bucket Seat
MOMO Trek R Steering Wheel
D2 Racing Ball Bearing Steering Wheel Quick Release
Razo Drift 150 Brushed Aluminium Shift Knob
Razo GT Brushed Aluminium Paddles Set
Pivot 80mm F1 Tacho with Sequential Shift Light
Pivot 60mm Gauge for Boost, Oil Pressure, Oil
Temperature, Exhaust Gas Temperature
Pivot Centralized Peak Hold Button
Re-Wing Centre Dash Pod
Trust A-Pillar Gauge Pod
Dugan Racing EL Dash Clock
Stainless Steel Dash Clock Surround
Skylab Traction Controller
Pioneer Stereo with some Sony Speakers
Edited by Nocturnal
Thanks for the comment guys.
As for laradly, what you said makes perfect sense.
This R32 does not flow, it wasn't ment to flow. And this is where it stand out from the rest of the R32.
However, the Standard R32 does have a lovely curve, and alot of die hard R32 lover want to hang me for doing it to their pride... :worship:
Thanks for the comment on the engine though. :)
  • 4 weeks later...
Hello Guys,
I know you guys ask for a video of the car, but never really had a chance to take it.
Decide to take the R32 for a dyno run to make sure the increase boost pressure isn't causing lean condition.
It was done at a show last weekend and one of the local tuners (THOR) took 2 Dynapack with them awith all the gears.
The first run made 597bhp at rear hub at 1.55bar (have to disengage the 4WD because Thor only have 2 Dynapack), but the top end is a bit leaner then I like.
The Second run made 573bhp at rear hub at 1.47bar and that was much much nicer! smokin.gif
This is a video of the first run, not the best quality, but sounded wicked in the tent. Keep an eyes on the crowd... Everyone scramble as soon as it hit full boost!!! chuckle.gif
Also, I give up on trying to figure out how to embed the video, if anyone help teach me, that would be great. thumbsup.gif
My mate took this picture last night... This is a Teaser I was told.
It looks like I just landed from space or something. I will get the proper pictures later this week, I'll post them up when I get it.
Welcome to Earth!!!! :laughing-smiley-014:
Thanks , the purple backdrop I think is "slightly" photochopped...
I think the background is more blue then purple.... Here is a couple more that my friend send me...
The Front Shot
The Rear Shot
The Underground Shot :)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
