Looking at fitting either of these turbos to my RB20. Any feedback from people who have experienced this engine/turbo combination 1sthand? I have been told I need a spacer plate for the Trust turbo but does anyone know if it will fit up to a split dump pipe? Any help would be greatly appreciated
https://www.sau.com.au/forums/topic/171078-trust-td0506-vs-gcg-hi-flow-on-rb20/
Ive got a GCG hiflow on my RB20. although it's not tuned yet so im only running 10psi.
but even then it goes alot better then the standard turbo ever did on 12psi and pulls all the way to redline.
Less response of course but not as laggy as you would expect.
Here's a link that gives some idea of the different impeller sizes on the MHI/Trust turbos vs Garrett.
http://www.900aero.com/main/tech_main_turbo.htm
I think a lot of the MHI gear is fairly heavily turbine biased, so Trust use a bit of mix-n-match to chase quick response. Pity that they use the 3 bolt turbine inlet, because genuine MHI turbine housings in TD05 and TD06 are evidently a T3 flange.
The Td05/06 turbo is a excellent match for the RB20 imo. It does require a spacer plate about 10mm just so the comp cover clears the manifold. With supporting mods you will get around 240rwkw. Cant remember about the dump pipe but any decent exhaust shop would be able to make split entry dump for it. Havent had any experience with the gcg hi-flow though so dont know which is better. BTW it is a T3 flange.
I had a tdo6 20g on my rb20 (240kw@wheel) and hated it. Lag, then wheelspin snap. Nothing at all in first gear unless u wanted to thrash the poor girl to about 7500-8. Same turbo now on the 3 litre motor and much much better. Total power not much more (280) but good grunt at 3 instead of 4500 - 5.
I 'think' it's a 10cm, but not totally sure. It was very very snappy on the rb20 tho, real hard to control power in lower gears. Straight line not too bad but try driving fast on a windy road - just forget it - I'd get beaten by a 180kw car easy. What a difference a litre makes eh.
Post in the rb30 dyno results sticky thread in FI. :whistling:
the t05 turbos are a direct bolt on for Rb20, they also come with a dump pipe that joins to any aftermarket front pipe.
the 16g is good for 200-220 at 1-1.2bar
the 18g is good for 220-250 at 1-1.2bar
have used both extensively, and are a great bolt on solution. the 16g is super responsive but runs out of puff up top if you want to make much more than 220rwkw without cams etc.. I find this turbo far to responsive and prefer to use the 18g.
Edited by URAS
^ mate i waited 3months for slide to high-flow my turbo. in the end i got my turbo back and went to GCG, same week got turbo and never looked back. do a search on slide turbo u will see alot of people are pissed off waiting.
What supporting mods are you running with your highflow? Aiming for 200rwkw's, I am hoping to get away with highflow, fuel pump, exhaust, cooler & remap. Want to leave injectors, FPR, AFM etc. stock at the moment due to money, or lack of. Do you think this would be achievable? Also what is lag like compared to stock?
hhmmm??? 'sif anyone would ever get pee'd f at Aaron, as nice a bloke as you'll ever meet.
I waited 12weeks for one last year (between Aug-Nov) and couldnt have been happier.
Slides overall health is of most importance; yes he does have a health issue and yes he does get very busy with the huge quantities of orders he receives for his hiflows. For the cost/quality of the unit I think its an awesome deal never mind if its a 3month turnaround.
If youd bothered to read his area of the forums, instead of stirring up crud:
"Hi Guys
Orders are now being taken for highflows again
We will not be doing the sort of numbers as we used to so when orders peek at 20 we will stop until all are done.
This is simply to reduce waiting times due to the amount of orders we receive.
The waiting times will always be stated at or longer then 3 weeks regardless of if it will be done in 2 days.
This will be to avoid any possible delays that may push back production including my personal health."
Slide highflow FTW !!11!!!!!
^ any experience with a td06 19c?
nah as it isnt part of the performance range, i think it was more a mitsubishi factory repalcement part, rated @330hp. Ralliart starions and pajeros.
Edited by URAS
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
