this is probably the worst discription ever
ok this is the only thing i can say, its like a filter type thing,but conects to intercooler pipe,or air filter piping,so if you suck up water through your air filter(pod)it will not getting sucked in to your engine
any one no what im talking about
any info would be great thanks
https://www.sau.com.au/forums/topic/171089-any-one-know-what-this-is-called/
A lot of cold air intakes that pull the air from under the car have a valve that prevents them from sucking in water. That way when you drive over a puddle you don't blow your engine, since water doesn't compress.. or combust for that matter. Ill try and find a picture. Might be called a back-up valve or something along those lines.
Edited by Rabid
I think this is what your talking about. It's called an Air Bypass Valve. It ensures that only oxygen and not a oxygen/hydrogen mixture (sometimes called water) gets into you cars engine. Here is an example of one that AEM makes.
http://www.autoanything.com/air-intakes/aem-valve.aspx
Edited by Rabid
yeah,thats exactly what im after,thanks mate,i will buy one tomorrow :thumbsup::D:):thumbsup::thumbsup:
