hi, i recently bought an r33 with a microtech lt8 sequential fire ecu, the car also came with a duel stage boost controller, but!, it has been disabled and tells me the ecu controls boost settings.
the car also has:
550cc injectors
dump pipe into stainless 3 inch
bigger turbo
front mount intercooler
pod ect.
= 221kw at the wheels
now... i didnt get a hand controller to change the settings, so my car is set on... what previous owner called economy, pushing 7 pounds boost and fuel is managed to run at certain level ect. and cant change settings.. when i ask people about it, they tell me it wont control boost settings. I dunno, who is right???
also if i bought a hand controller. will the settings the previous owner used be loaded up from the ecu? or are the settings (maps) saved on hand controller? will this mean i might have to get my car re-tuned on dyno?
if anyone has any info (cause it has me stuffed) hehe, that would be great.
thanks
https://www.sau.com.au/forums/topic/171090-microtech-ecu-info-please/
if you dump more boost into it, then the tune is not correct for the amount of boost you raise it to, if you want more power raise the boost and get a retune done on the ecu.. the handcontroller is only usefull to a user if you want a read of digitaly, for a tuner it can be used also to tune the car, so be carefull not to hit the *mode* button when you get one as this will set the computer into tune mode, and you will alter any settings... not advised unless you know what your doing.
so im stuck on 7 pounds of boost, unless i get it dyno tuned?
Economy and microtech should never be used/talked about in the same sentence, they don't belong together :thumbsup:
I'm sure you can tune the microtech for "economy", but yea, it's pretty p*ss poor in that department.
I probably got a MAX of 300-350km/tank(60L tank) with the RB20-DETT, and i generally drive pretty old lady style.
And no microtech can't control boost.
Edited by Jago
