I have a problem with my rear end violently shaking under full power when accelerating.
It feels like axle tramp but its real violent. Ive been told its not axle tramp because its irs
but thats what it feels like, and it is bloody terrible.
It feels like the rear wheels bouncing up and down real quick real violently.
Is it my rear suspension set up?
Is it my diff?
What is it? It only happens in the 1st and 2nd under full acceleration.
car is mr30 sedan, man with an R200 viscous lsd.
Anyone help or had the same problem?
My gut feeling says its the suspension...
https://www.sau.com.au/forums/topic/171109-rear-end-violently-shakingbouncing/
when i had a VL turbo wagon, the bearings in the gearbox were worn causing vibration in 1st and second under heavy load.
also the rear wheel bearings needed replaceing , so these 2 things could add up.
the mechanic says it was all caused by a un-balanced tailshaft...
Thats one thing i havent taken into consideration purely for the fact that this car has seen 4 tail shafts, from stock
to modifying it over the years for different gearbox and diff and the one time it broke the rear uni. I didnt think that
all 4 tailshafts could be out of balance, especially with the last one being bran new.
Ive been having this problem ever since i chopped the rear springs years ago. Since then ive changed the tailshaft
3 times and rear suspension 3 times. The only thing i have not changed yet are the rear wheel bearings. I thought
that these only get changed when they are noisy?
I just thought it was the use of crappy springs in the back that are too soft and have a bad rebound quality or something
along those lines.
Its just real annoying, sounds scary in the car and i know it's not right and needs to be fixed :)
How to prevent axle tramp? Well, how about - "stop dumping the clutch"?
But generally, axle tramp is caused by the shocks and springs being totally mismatched. So, yes, it's a suspension thing.
when i dump the clutch it just fries the tyres. It happens more when i ride the clutch into power then release it.
Then when i snap second and squats down it does it again. Then into third it disappears due to rolling speed and lack of power. It doesnt squat as hard in third. So thats why i was tending to a suspension problem.
Any recommendations for a good rear suspension set up?
A-ha! From what you describe, I am 99.99% sure that the problem is the clutch. There is oil on the clutch plate. This causes the clutch to "grab" rather than slip, and results in a "shudder" in the driveline. Been there, had that.
You are going to need to pull the box out, replace the clutch (the clutch plate is fooked now), clean the flywheel (if not have it machined), and put the lot back together.
Edited by Matty T
serious? i would of never thought that!!! why on earth would there be oil on my clutch????
does make sense though. at least now im glad its not the rear suspension. that would explain a lot. its also one of the
things i have not changed!!! ive changed diffs, tail shafts, cv shafts, suspension the works! looks like the clutch is next!
thanks for your diagnostics and help.
All it takes is a leak from either the rear main engine seal (common) or from the gearbox input shaft. With a bit of bad luck, oil can get sprayed onto the flywheel, then to the clutch plate.
The other possibility is that either the clutch plate has dropped one or more springs, or the pressure plate has started to fail. Whichever problem it is, I am pretty sure that your issues are clutch related.
I didnt realise oil could cause so much trouble. I would have thought that it would just burn away.
That is also why you need to make sure your hands are clean when you handle the clutch and pressure plate. You don't want to transfer any oil onto the surfaces.
Replace the seals if they are leaking, yes.
Before you do get a new clutch, have you checked all the mounting points and rubbers for the diff?
None of the rubbers are torn on the moustache bar. Should there be rubbers between the diff and the rear cradle?
For memory the four holes that are bolted to the rear cradle have no rubbers, just nuts and bolts. But i had the same
problem with my old diff too.. Its very odd.
  • 2 months later...
I just wanna say thank you for your diagnosis. You were spot on! Just got around to finally changing the clutch and it has cured all my haunting troubles. Thank you!!
You may also want to inspect and check your rear engine mount. Even if it doesn't look like it has cracks in it, it may be very soft, and causing driveline vibration on take off. Rear engine mount actually hold the gearbox up, in case you haev trouble finding it.
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
