Hi all
I need to confirm who is wanting to be a judge at the Show and Shine. As a few have said they would i need this to be confirmed
Please give me your name and User name and also car you drive as I can sort out what catigory you will be judging.
https://www.sau.com.au/forums/topic/171123-show-and-shine/
Ok judges at present time who have sent me a PM or I have spoken too are as follows
Adam Ownes R34 GT-T
Jess Ownes R32 GTR
Nick Ownes Stagea
Chubs Ownes R33GTS-T
Blitz Ownes R33GTR / R32 GTS-T
Craig Ownes R33 GTS-T
Paul Ownes R33 GTS-T
Corinne Ownes R32 GTS-T
TJ Ownes R33 GTR
Nick Ownes R32 GTR
Smokenhowzen Ownes Nothing? HAHAHA Ownes R33 GTS-T
Vic R33 Ownes GTS-T
WTF33R Ownes R33 GTS-T
Me Ownes R33GTR
Ben-m Ownes R32 GTR
Trust 33 Ownes R33 GTS-t
Silver-Arrowz will be judging
Endorean (MATT)
Stuart from Pro Coat
Craved (Chris)
Merli
someonestolecc (TOM)Project Mayhem r31
I know Stephen ( DRIFT KING)skylinegtts
Jetr32
https://www.sau.com.au/forums/topic/171123-show-and-shine/#findComment-3157751
i reckon there should be prizes for
Best burnout
best drifto
best drift damage
omgwtfbbq rims
are you blind
Getz the Lookz
as for judging ill be right.. enough of an effort showing up :D
weak sauce :thumbsup: :laughing-smiley-014:
https://www.sau.com.au/forums/topic/171123-show-and-shine/#findComment-3157972
evil you where not drunk it was that you had to much blood in alcomahole system.
We had
Adam Ownes R34 GT-T
Jess Ownes R32 GTR
Nick Ownes Stagea
TJ Ownes R33 GTR
Nick Ownes R32 GTR
Vic R33 Ownes GTS-T
Me Ownes R33GTR
Ben-m Ownes R32 GTR
I know I am missing someone. And does this look right to you ?
I know Stephen ( DRIFT KING ) Want to Judge R32 Gts-t
Looks OK to me
https://www.sau.com.au/forums/topic/171123-show-and-shine/#findComment-3159192
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
