they didnt give you any install instructions??
Definately looks like the Turbosmart one
try here
http://www.turbosmart.com.au/index.php?s=downloads - should have the instructions
hi,
no it didnt come with instructions thats y i'm confused :)
try here
Probably best not to until someone who knows what theyre doing says something lol
But i wouldnt leave it without a hose connected to it... run the hose through a hole in the engine bay somewhere or down out of the way.
And make sure you have the T peice the right way... ie. arrow towards the actuator... not towards the Turbo and the bottom part (red part of the T) runs to the controller (which until you get it turned on a dyno should really be completely closed)
it works as in in-out type device
be careful when messing around with boost control, if you do it wrong your car will run unlimited boost. that is, if you load the car up and its setup wrong boost wont stop rising so youll just do damage or fry something
intercooler pipework -> hose -> stock valve IN -> stock valve -> stock valve OUT -> turbocharger actuator
on the black intercooler pipes there is a nipple already. it has a tube on it that runs to where the turbocharger is.
its about the same size if not a bit thinner then the red tubing in the photo. you basically interject your unit in replace of the stock boost solenoid
intercooler pipework -> hose -> turbosmart boost valve IN -> turbosmart boost valve -> turbosmart valve OUT -> turbocharger actuator
so basically find the stock boost solenoid and replace it for your turbocsmart device then away you go.
the device is next to the right suspension tower, its attached almost next to it. with two tubes that run to it and some wires.
undo the tubes from this and run them to your turbosmart device. drive around and experient.
as you load the engine up watch the stock boost guage and make sure it doesnt hit +7 if it does, youve done it wrong and are running unlimited boost (this is bad)
all you do is replace the standard boost controller in the r33 with the one you bought. it acts in the same manner that the standard1 works. bottom hose on standard, to bottom port on new, and same for the top.
providing your standard boost solenoid is set up correctly, you should be fine.
ill get a pick later tonight of my set up of the standard solenoid and point out on the pic where the pipes go.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
