Mine has this, and it turns the headlights off after the interior light turns off, which is 30 sec after the turbo timer shuts everything down. This may be a feautre of my alarm though, because the interior light goes off, the headlights turn off and the alarm auto arms all at the same time. If I self arm the alarm before the turbo timer shuts off, it stll turns the lights off at about 30 sec, but only if they are on auto. If they are on manual they just stay on.
Oh, and I say do it! The best thing about JDM cars is all the stuff they have that domestic cars dont. F'r instance did you know that apparently the new holden astra hatch has a brand new innovation for 2007? Thats right - a self closing hatch! 10 years later......
Fair enough on the girlfriend thing then. My girlfriend just got her licence (bloody time) and i get in the car with her at night and she starts driving off with no lights... I ask her "can you see alright" and she says "yeh, not bad"....then i turn the lights on for her and she is like, "oh" :cool:
But as Cyrus asked, doesnt she get beeped at galore. If I leave my lights on the bloody thing wont stop beeping until I close the door, by which time I understand why its beeping. Either way though, I think the autolight feature itself is pretty useless (Had autolight in 2xcelsiors I owned) as Luke said they turn on a bit late and tunnels are annoying. Cool, but useless.
Good luck sorting the issue of flattening the battery either way.
Just bought a 1996 RS Four V it has the Auto lights... with the light sensor on the dashboard (drivers side) and since the car has a turbo timer, the auto-off when you leave the car does not work... which sucks cause otherwise I would use the auto lights...
They do turn on and off a bit if you're going through the trees etc, and start on park/driving lights when it's not really dark...
would be good if the turbo timer (which I might disable anyway) didn't screw with that circuit...
The car manual (aftermarket translated one) I have says they are meant to turn off when you leave the car...
just my 2 cents
Auckland, New Zealand
1996 Stagea RS FOUR V
Leather Seats (not heated), Stock, except: Bilstein shocks, Tein Springs, GTR intercooler, Cat replaced with straight pipe, Boost gauge, Larger trans cooler, Pod filter, aftermarket rear muffler, Dynatron alarm/immobiliser and turbo timer.
wouldnt it be cheaper to just get a new girlfriend that knows how to operate headlights?
i will tell her that but i would prolly get slapped to death HAHAHAHA (no really)
so no it would not really be cheaper to get a new one! unfortunate cos due to update to a new model something shortly hehehehe
Edited by oxford1327
just to clarify for the sarcastic ones.
it is not i that requires the auto light jigger for the car it is so my girlfriend does not continue to leave the bloody lights on and flatten my battery again, as she is a crumpldore driver and her car has the light jigger on it.
i am quite capable of turning the lights off/on my self but she seems reticent to obtain this skill.
cheers oxford
if it all works proper when you pull the keys out it will beep at you no matter wether you have a TT our not
cheers oxford
an alarm will come on even if the lights are on the keys are either in the ignition or not !
all good advice guys and while i am fully aware of the incessant beeping etc coming from the car, when "she who must be obeyed" gets out of the car she must suddenly develop domestic deafness of some sort and ignores it, so short of putting a siren as loud as a cop car in the loop for the lights. i just bloody want the auto light bejigger as this would be much more "user "friendly.
cheers oxford
  • 3 months later...
just thought i would put an update in this thread as i forgot all about it ooops!
i managed to get hold of a stalk with the auto light function on it but the plug is different in shape as well as having different pins in it so alas it does not fit :domokun: .
however now at least if someone else is thinking of doing the same they will know now, if they find this thread that is.
i didn know you could buy auto light bejiggers as an aftermarket item from supercheap or the like so i will endeavour to check it out before i go back to work on friday
cheers oxford
Yeah, I have the auto light feature and think it is over rated, it really doesn't turn the lights on until it is too dark (for me anyway) so I always override it.
I have also found that the auto lights turn on too late.
I found that by adding a layer or two of dark window tint film over the auto lights sensor, the lights will come on earlier, and lessen the flicking on/off effect going under bridges.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
