pretty sad that ive been driving the car for a year and i still dont know what this button is for .... lol.
the button is located on the left hand side of the streering wheel
sorry about the quality of the pic i took it on my phone at night.
https://www.sau.com.au/forums/topic/171139-diff-lock-button/
don't see how it can make a difference - unless there is wheel spin it doesn't matter about what the torque split is off the line. And I'll be stuffed if I can get any wheelspin no matter how much I abuse it.
Exactly.....
Mine neither.... In theory using the 50/50 will limit the torque to the front/rear, and therefore if you encountered wheelspin, it just might actually be slower off the line. If you get wheelspin.... get fatter tyres!! :laughing-smiley-014:
The auto trans is that clever that I just let it do it's thing.... in this case computers rule..... (probably 'cos Bill FN Gates had nothing to do with it. Otherwise you have to have the windows open to start the fkin thing!!!).
Exactly.....
But I was under the imppression that the 50/50 diff lock just starts off at that ratio instead of 95/5 AND still distribute torque accordingly.
This is more correct. After a certain RPM (or at least once you get higher into the rev range, say over 2500rpm?) the awd system will still put more torque to the rear as necessary, but will favour 50:50. With the button off, its the same principle but it would instead favour 95:5. Hope that makes sense :thumbsup:
As far as being faster, I would imagine it WOULD be slightly faster mainly because driving the front wheels will likely help with the weight transfer, not sure if this is correct - I might be way off the truth, but IMO it would be better to share the acceleration over all 4 wheels, than just the rears...who knows?
In any case, under full load the awd system will basically be running 50:50 torque split anyway, so the difference between button on/off when under hard acceleration is probably nil or at least minimal. :D
It is worth noting however that the system is not really designed to be used in 50:50 mode full time for daily driving and a few people have cautioned using it like this for fear of burning out the clutch packs prematurely... I'd like to think it was built strong enough to handle it but I'm not willing to risk it :) Occasionally I'll use 50:50 for driving in the wet but only in extreme weather conditions and bad road surfaces...
well who knows, in practice I think it would make bugger all difference...but on the dyno our gtr makes about 10% at the wheels more in RWD than in 4WD
You definately don't want to run in 50/50 mode all the time, we burned out the clucth packs in the race car running lots of front torque in about 30 minutes - lost all fwd until we rebuilt the transfer case
With 205's + wet road = 4wd spin from a standing start, with the 50/50 button pressed or not. It's really weird when the car does not move forward, rather lurches suddenly sideways, following the lean of the road.
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
