I have just been reading up on compressor surge all afternoon particularly in relation to low rpm on an RB20. i have dug up some stuff on sau regarding this topic when incorrect wheel configurations in highflows can cause a compressor surge at low rpm, what im unclear about is would this only occur at full boost or can it also occur whilst building boost? and how?
as i understand from what i have read is that the compressor wheel will push x amount of air out and if the pressure between the turbo and engine is greater then what its pushing then it will be forced back thru the compressor causing surge.
now how would this occur in a low rpm situation when the boost pressure isnt that high?
what causes the engine to restrict this compressed air entering the combustion chamber?
could an incorrectly setup engine cause surge or is it all to do with a spiking turbo?
i have theories on incorrect inlet cam lift duration or timing....but im not a qualified mechanic or an engineer and could totally be off the mark so opinions would be great!
https://www.sau.com.au/forums/topic/171149-compressor-surge/
surge typically occurs when you start to build boost, the blow off valve is not going to vent at low pressures, so the air gets pushed out the compressor. can happen at 0psi, can happen at 20psi, pending if u how tight / if u even have a blow off valve
does that help?
Edited by InterCooL
does that help?
it does clarify that point but im also trying to figure out where the problem occurs in the engine. as positive boost builds it should be drawn/forced into the chambers so what would cause it to bank up and surge?
in my particular case the turbo is a constant and 2 different engines are the variables...
edit: i should add that im refering to during the spool phase... not off the throttle BOV type scenario.
you're getting surge when you are spooling up? :)
you cannot be doing that. you must be mixing 'surge' with something else. but i cant imagine what
yer im really confused...
I just cant understand how 2 RB20's can behave soooo extremely different with the same tune and mods hanging off em.
just relating everything i can find to the situation.... SAU is killing my brain cells
--END THREAD--
Yes you can have that.
You can have compressor surge as you build boost.
Generally due to a comp wheel that's too large to the rear. Can happen in low RPM definitely as boost is created.
Basically the comp wheel is flowing more air that the motor wants at that stage, once you overcome this its ok usually
i notice compressor surge on my r33 with a plain bearing hiflow, Front wheel was off a isuzu truck. Old skool design To4
what appeared to be happening, is that the turbo was generating way too much air that what it should of, at start of spool phase.
This was at 5psi, and then we believe the bov started to pulsate, pushing air through the plumb back pipe into the intake, then too my afm.
The afm recognised more amount of air, getting pushed through, so it dumped more fuel into the engine. I didn't notice this surging when i have the standard airbox on with my standard afm, as it mighten of not of been as sensitive as the z32afm, and the apexi pod filter being able to suck ???
I didn't get around to fix this problem, but i believe it was either relocating the afm to another position, change the bov to atmo, or putting a stronger spring in my BOV.
Then again these ideas could not of worked either.
I have now changed turbo setup, so see what happens. (also going to put a sharp bend in for my intake pipe)
Yo, IZ32
Please visit Garrett's website:
http://www.turbobygarrett.com/turbobygarre...bo_tech103.html
This is all pretty advanced stuff, just read through and filter out most off it and learn what you need to know about Surge. There is a few paragraphs about a 1/3 down the page.
This should help explain it a lot.
Slim
i had a gt2876r 0.86.
massively oversized compressor relative to the exhaust wheel. renown for it. i hated the setup. but i never had any strange induction / surge noises
not saying its not possible, but if a gt2876r doesnt give you it, then you're not going to be getting it with a hks2530 that iz32 is using?
Happens with big (relatively speaking) boost, at low rpm. If you look at a compressor map for a turbo, you'll usually see a dotted "Surge line" running up the L.H.S. of the map. This is where the compressor can't push any more pressure at that flow-rate, and stalls (like an aeroplane wing stalling, or a boat propeller cavitating). It stops pumping & sheds a tonne of boost pressure and (turbo)rpm, until it can re-establish compressor flow & start building shaft rpm & boost again.
If U keep the clog in, this keeps happening in a cycle, and U get compressor surge. Wind down the boost at low rpm, or back off the throttle when U hear it hissing REAL loud just before it stalls (and makes the ssssSSSSSCCHHEEW sound as it stalls the compressor). Good luck :D
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
