Hi guys
I have a used Video Card which i don't need anymore
Its a Leadtek A7600GS
I brought it about a month ago and had it on my comp for about a week then i got my Motherboard chnaged and now i have no use for it .
Here are the prices i could find for it new online
http://www.shopbot.com.au/p-48511-728612.html
I paid 200 myself but if anyone is interested you can pick it up for 100
I live in western sydney in the penrith area i would prefer not to have to post it.
But it does come with all the CD's and the Box it came in..
WinFast A7600 GS TDH
Features:
· Built for Windows Vista
· Proven Shader Model™ 3.0 technology support
· Fan noise under 30 dB
· Supports CineFX™ 4.0 engine & UltraShadow II Technology
· Supports Intellisample™ 4.0 technology
· Supports HDTV, Dual link DVI and D-Sub output
Specifications:
GPU - GeForce 7600 GS
Graphics Bus - AGP 8X
Memory size - 256MB DDR2
GPU/Memory clock - 400/350MHz
Memory data rate - 700MHz
Memory Interface - 128-bit
Memory bandwidth( GB/sec.) - 12.8
Fill Rate(billion texels/sec) - 4.8
Vertices/sec (million) - 500
Pixels per clock (peak) - 12
RAMDACs (MHz) - 400
Connectors - HDTV-out / Dual link DVI-I/D-Sub
Multi-Display - Yes
So if any of you guys are interested PM Me OR CALL 0421822912
Thanks
Pac...
Edited by Pac
  • 4 weeks later...
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
