Guest KMale
Well I just picked up GTS1 SVD #157 and I must say ...I had almost forgotten how much fun these cars are. I sold these new back in 1988 and the way they drove then left a lasting impression on me.
Technically this is the wifes new drive car as she wanted to quit the Hyundai Lantra wagon. She claims it leaves her feeling brain dead which I understand perfectly :O Anyhow ...expect to see Cambo and I rock up with it at the next cruise ...I don't need much of an excuse to strap this baby on :P
Not sure if we will make it to the drags this Sunday but we will try. Does anyone have any idea how long the lane is booked for ? Like will people still be there at 2 or 3 PM ??
ps. Anyone want to buy a Lantra wagon ?? It holds lots of stuff and doesn't drink very much :)
https://www.sau.com.au/forums/topic/17118-just-got-me-a-gts1/
The day finishes at 4pm, starts at Noon.
Last entries to race are at 3pm.
I'm only takin my Pintara wagon and will probably only do 2 or 3 passes so I doubt I'll still be there...
If you could be there at 2 there should be plenty happening, by 3pm things will be winding down a bit;)
Guest KMale
For those that like to see pictures ....well here are a couple that I have taken today. You will see that the previous owner hacked up the front grill (i'll strangle him) because if was getting too hot idling in traffic with the air/con on. He didn't think to replace the viscious coupling fan clutch which is stuffed.
www.enabletech.com.au/war31club/GTS157/index.htm
Guest KMale
The guy was asking $9000 but I didn't think it was worth that. I wont say what I paid but I expect that if I put it on the market here in Perth I would get somewhere between $7000 and $8000 as it is.
The drive line is pretty strong with only a few minor problems. The interior is also above average condition with only a couble of blemishes. The body work is above average condition but I am planning to give it a coat of paint and sort a couple of ripples and minor blemishes out.
I really want to get rid of that hacked up grill as well ...it annoys me :P
Shit yeah he hacked up the grille alright!!....iiiidiot
I got this bit of info once as I was lookin for one........If you buy one let me know I might grab one as well.......discount for 2 :D
"ring ml wreckers the link is on the top of our web page (r31skylineclub) speak to max he can put you in contact with the guy who has the mould and sells them"
Guest KMale
22nd June would be nice. Hopefully I will have some better quality tires by then. My wife is keen to have a go at the quarter mile so I don't think having the GTS step out sideways on her would NOT be a good idea.
Cam is not quite ready to take the GTS down the strip ...maybe later in the year after I have taught him how to launch and how to drive fast without destroying the car.etc.
KMALE
My daughter pointed that one out to me in the Auto Trader as she knows I want another one. Unfortunately building a new house plus garage is full ATM.
Having said that if anyone sees #101 I want it back for a full restoration:)
Cheers
Guest KMale
Hey R34 ...my garage is worse than full ...its spilling out onto the street. Last count we got 5 cars here. I need to sell the Lantra wagon bad ...its such a pain shifting these cars about LOL However I just couldn't resist the GTS ...I have wanted one of these forever and the price was right.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
