Item: 19 x 9.5" Work KH wheels and tyres with +30 offset to suit GTR
Condition: Excellent
Has 265/30 Pirelli P7000 tyres with 50% treadon rear and
NEXEN SILICA TYRES 235/35ZR19 strecthed on the frotn brand new never driven on
i got these of NXTME on these forum they are a beautiful wheel one of the best wheels i have seen all balanced and tyres on
these come with small 6mm spacers to fit on a r33 gtst need to roll the guards and the rears pumped out a bit
im after a swap or a out right sale i have a r33 gtst i just wanna get it back on the road
im aksing 2,500 2,200cash without front tyres very firm as i just put new tyres on them these rims are huge
Edited by teazn_r33
nice wheels. so they would go on a r33 gtst? only have to flare guards yeah? did you really get offered 2000 for them???
ok interesting, i have a set of 17inch volk racing rims at the mo, nice wheels, rare style, looking at bigger... how much would it cost to get them freighted to tassie 7140?
i have no idea about freight to tassie you might be able to help can u please send pic of wheels if you look to swap im sure for the right price i could arrange freight but you might nee to help as there is alot of water between us lol
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
