QUICK QUESTION....JUST WANT TO KNOW WHAT THE MAX & SAFE BOOST ON RD20 STOCK TURBO CAN HANDLE?
SETTING : STOCK RB20 DET 107000 KM
AIR FILTER
3' CAT BACK
MANUAL BOOST CONTROL
FMIC
SFC-HYPER R http://www.field-net.co.jp/english/lineup/hyper-r/
CAR CURRENTLY RUNNING 1.3 BAR...... BUT I DUN WANT TO BLOW THE TURBO, WILL GO DYNO ASAP...
Edited by whyau1
https://www.sau.com.au/forums/topic/171198-max-boost-for-rb20det/
The stock turbo has a ceramic turbine. Don't push it too far because it'll let go alot easier than a steel job. 1.3 bar sounds high to me. I wouldn't push mine above 1 bar, but i might just be over cautious
Edited by D3LTR33
There is really no point to runnig more than 14 psi or 1 bar through a standard RB20DET turbo. For starters you'll have bits and pieces of your turbo go through your intercooler piping and/or exhaust and the turbo is basically pumping hot air into the engine as it is well out of its efficency range at 1.3 bar :S
the rb20 uses a ceramic turbo but the front and rear wheels are steel so there not as prone to failure as the r33 series 2 ones. if i were you i wouldnt go over 13.5. with a boost spike it might just touch 14.5. keep it safe on 13 psi
:):D:thumbsup:
when i had a std turbo RB20 i never went past 10psi. Like mentioned, ~13psi would be the "safe" upper limit. Anything more and you are bound to run into problems eventually/decrease the "life expectancy" of your turbo dramatically.
What the hell are you talking about mate? LOL... the exhaust will IS ceramic. Thats why its a ceramic turbo...
14psi ran fine through my old rb20 turbo but 19psi is pretty excessive.. I'm now running 12.5-13psi through an rb25 turbo on my rb20, anymore and it pings over 6000rpm (untuned ecu) once my 044 goes in and I get an ecu I will wind some more boost in and test the limits of the 25 turbo :)
when fitting my stock rb25 turbo to my rb20
i hit 24psi before a loose cooler pipe blew off.
it is possible but i wouldnt recommend it.
when i got it tuned to 12psi,we tried for 14psi but the extra 2psi only gained like 2-3kw
plus had to do unsafe stuff with ignition timing,so i settled for 12psi with a safe tune.
1 bar or 14/15 psi upper limits. Buy a highflow from sliding performance or a GCG rb25 turbo.... and support those mods! FMIC exhaust, fuel pumps, piggy back fuel computers! etc or just get a rb25 turbo from a r33 s1 or s2 (different turbines but nylon vs Steel wheel)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
