Hey all have a Dato 1600 project that i havent finished due to low funds i'm looking for about $3000 $2500 ono or trade for S13/A31 shell
-all interiour VGC (all original)
-SR20 Datsport conversion crossmember
-R31 seats & Breaks
-Car will be 100% in primer when i get time to finish it.
I live in Caboolture PM me if interested or got any questions.
Thankx Davo
post-26193-1180944412_thumb.jpgpost-26193-1180944461_thumb.jpgpost-26193-1180944501_thumb.jpg
Edited by Driftin~Davo
https://www.sau.com.au/forums/topic/171209-fsswap-1600-shell/
Hey all have a Dato 1600 project that i havent finished due to low funds i'm looking for about $3000 ono
-R31 seats & Breaks
Thankx Davo
Pics?
And what's left to get it on the road?
What other mods, suspension? diff? etc
And the datsport cross memnber? is that just the crossmember or the whole front end kit they sell?
Pics?
I got the whole front end kit and installed it myself, i even got the Datsport bump steer bracket they sell.
To get it on the road u will need a motor and box, tailshaft needs to be shortned, you would probally need a break upgrade to get it mod plated the non-dodgy way even though i've seen SR 1600's wif the standard drum rears lol.
Other then that its a granny spec 1600 wif a verygood body no rust and once i've put the whole car in primer i'll chuck up sum pics.
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
