Keen to know what the resistance valves for the dash gauge are for the rb25 are. Ive put a 25 into my 32 and i cant get the dash gauge to work... its all hooked up to the right wire. Have had the motor running for quite some time and the temp gauge just wont move.
So the single pin blue/black wire that goes to the dash.. what reading does it out out at cold temps and at operating temps.. does anyone know?
https://www.sau.com.au/forums/topic/171224-rb25-coolant-temp-sensor-values/
Ever consider the sender might be kaput? Have you tried using the sender from your old RB20?
To confirm the gauge works (which presumably it did before), try earthing the sender wire (with IGN = ON) - if its the same as for oil pressure, the temp gauge should go to "full scale".
already done that, thats how i know the wiring is right since i earthed out the connector from the sender (took it off first) and the gauge reads full. sensor may be busted... but i have had the multi meter on the sender and it reads around 150 ohms resistance with the motor running for about 15 mins... so i have no idea if that means operating temp or what... since the dash gauge reads full with 0 ohms... so i assume the lessere the reading the hotter the temp?
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
