Being the optimistic person that i am i like to think despite what happend today.... it was a good thing :P
As you all most likely know of the last 8 months i pretty much collected (apart from the engine) the front of a GTR :O as in Guards, Bar, Sides (technically not front i spose) and cooler.
I ended up selling the cooler to Adz and was going to sell the other bits and my car or give the parts away to the person who brought it...
plans changed thanks to a ****ing stupid bolt sticking up out of one of those concrete spacer things at the front of car parks... peice of crap!
http://members.optushome.com.au/sau_vic/damage.html
As you can see the plastic bar is pretty much ****ed... so out of bordem (and the fact the front bar is rooted) i decided i would chuck those GTR parts on... and hence begins Project R :)
https://www.sau.com.au/forums/topic/17123-some-good-came-out-of-todays-mishap/
  • Replies 40
So far all ive done is removed the old front bar and left guard and put the left front GTR guard on.
Looks a bit odd with the stock wheels haha might have to see if i can get my hands on a pair of front GTR rims so the offset sits and makes it look proper.
Theres some minor rust on the front which i will fix while the front bar is off... nothing too hard.... just sand it back to shiny metal and give it a couple of nice coats of primer putty and black it.
Originally posted by funkymonkey
wtf... when was this... y fix it 4? jus patch it up and keep it until you sell the car... so you don't run the risk of pranging it...
earlier today after i washed the car :O
meh... i got the parts here already why not wack em on.... get it all painted at once... if i can use my uncles next door neighbours spray equipment and garage it wont cost me a hell of a lot... plus i kinda wanna sell it knowing its in top condition.... im gonna miss it man.
EDITED***
anyway.... plastics not that easy to fix when its torn like that and wont last long unless plastic welded.
yup...
going to speak to the old man and see if he will lend me the money to get the R til i sell both my current cars... as well as borrow the money to paint and ready this for sale :O
i might atucally end up suing the shopping centre as my car is the legal height.
going down there to measure the height of that concrete thing with the bolt sticking out of it. My mum told me one of her friends sued a place that did that to her car cause there werent any warning signs to say they were even there.
why i dont want to own an R33 GTR.... i dont like them as much. If im going to own a GTR its going to be a 34 or 32.... seeing as i dont have 70k at the moment the 32 will have to do :P
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
