I've had enough of my apexi springs (yours for $200 if you want them, great for drifting).
I'm deciding between whiteline or king springs (lows) as a replacement. I'll be using them with my existing bilstein shocks.
I realise the kings are progressive whereas the whiteline are linear on the front.
Anyway, I just want to know the rates of each spring, front and rear?
Also if you have an opinion on which is better, feel free to post it here.
Thanks
Greg
https://www.sau.com.au/forums/topic/171264-king-vs-whiteline-springs/
If I remember correctly, Gary (SK) said the front Whiteline spring is 165lb/in (2.92kg/mm) and the King spring is ~175lb/in (3.1kg/mm).
Dont know about rears though.
I'd say the Whiteline one is the better spring though as it's cold wound compared to the hot wound King Spring.
Edited by salad
Yes, you can swap them.
Any of the major spring manufacturers will be able to supply replacements as they are likely a 65ID spring so very common.
You will need to take into consideration your current spring rates, front and rear weight and range of adjustablility when getting springs with lower rates, particularly if your coil overs dont have base height adjustment, or if you already have the spring seat up near the top of the thread, as the weight of the car will compress them further, so you will need to either get a longer spring, or wind the spring seat up a bit more (if you have enough adjustment).
Scandew: Get a tape measure out and measure the ID. If you cant get in there to do that, measure the OD and then subtract the wire diametre twice. Find the wire diameter by sliding open ended spanners over the top till you find the right one. Does look like it'd be something around 60-65mm ID though as that's the norm for rectangular coils.
R DITRY 3: I've seen SK say a few times that they are cold wound. I know just going by what people say on the internet isn't the smartest thing, but I think SK has a fair idea about all the Whiteline stuff.
Edited by salad
The Whiteline R32/33/34 springs are definitely cold wound on a hydraulic, computer controlled coil winder (the same as Eibach, Jamex, H&R, Bilstein etc). This gives a superior/more consistent result than hot wound coils. I chose the Whiteline springs for the Group Buy because of this quality/consistency, plus they had rates that better suited the rest of the kit. The R32/33/34 front springs are linear and the rear springs are progressive, like the Kings variety, they are progressive to keep the coils trapped at full droop.
For the record, a linear front spring is far superior in driver feel than a progressive, which gives differing results depending on weight transfer and therefore inconsistent steering feedback. I wouldn't use a true progressive spring in the front of a Skyline.
:rofl: cheers :laugh:
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
