I'm not too sure for you, I'm getting the cushioned button as I still want some drivability for my daily, but need a lot more bite than an organic. Have driven an Extreme cushioned button and it was nice.
hey mate,
ive got an extreme HD cushion button and i can vouch its a definitely nice clutch to drive, clamp well... and definitely not too heavy either. As BAMR33 has said, they are quite bitey and need to be engaged without riding it. pretty much need to be on or off.
though i am not too sure if it will be able to hold 300rwkw. anyone who has tried and test want to shed some light on this.
btw BAMR33 how long have you had your clutch for, How many KMs? how much power are you running? i hope my clutch lasts for a while still.
cheers
:sleep:
Edited by R33LIN
My extreme XHD 9puk ceramic with the std flywheel went for ~40,000km's before I started noticing slip on hard gear changes. Slip to the point where you have to back off the throttle and then jump back on it for it to hook up. At 60,000km's and it slips like buggery.
And it was only making ~200rwkw but a fair bit of torque as that was around 4500rpm. :S
The XHD is stupidly heavy. I curse it every time I'm in traffic, not because of the ceramic grab but because of how heavy the bastard is.
cheers for that cubes,
i do hope my clutch lasts for a while though. its only 10,000kms old
the costs of a clutch and the associated labour is painful, definitely dont want to fork out that amount of money anytime soon.
:sleep:
:sleep:
x2, i just put in my HD cushion button from slide. Feels good for the moment, and im just hoping it lasts for a while.
Yeah, I've driven a couple of cushioned buttons now, one in a silvia and one in a 32, and loved both of them. So much more grab but nice to drive.
Not too fussed on how long it lasts, I've made my HD organic last 2 years and 27,000kms so far and its still going OK, just really doesn't have the bite that I want. Running around 170rwkw and lots of track drifting (clutching a lot, especially with a no-midrange RB20 :sleep:)
As long as it lasts similarly to this one, I'll be stoked.
C'mon people! Get in on that groupbuy! I want that extra $50 or so off! :O
Edited by salad
Not too fussed on how long it lasts, I've made my HD organic last 2 years and 27,000kms so far and its still going OK, just really doesn't have the bite that I want. Running around 170rwkw and lots of track drifting (clutching a lot, especially with a no-midrange RB20 :D)
there's too much of a choice in the group buy, haha!
doing my tax tomorrow so hopefully i get a bit back and soon!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
