Hey guys,
ALREADY SEARCHED FOR MY ANSWER ON HERE AND ALSO NS.
I've heard a romour that running my GTS4 in RWD mode (removing the fuse) for drift, Does not run the same as a GTSt and has bad balance??
It's been a dream of mine since i was 14 to learn drift and get to the track. My engine is currently shagged atm, so this may be an opportunity for me to switch to a GTSt drive train while the engine is out....
Anyone have any experienced opinions or guidance they wanna share??? :P
cheers!
https://www.sau.com.au/forums/topic/171278-gts4-and-gtst-rwd/
Honestly you really didn't search.. did you. There's heaps of info on here.
The short and curlies of it is, when you lock a gtr/gts4 in rear wheel drive, you are still carrying all the weight in the front end of your car.. theoretically upsetting the balance of the vehicle compared to a designed for rear drive vehicle. As well as the vehicle being proportionally heavier.
So.. you can do it, but why not get rid of your car, cos you obviously just want something to thrash, and get a bunky gtst, slap a 25 into it, and go nuts.
james.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
