Hey guys Im looking for the stock r33 rear muffler. I only need this for epa so i'd prefer to buy cheap otherwise fi any friendly melbourne people out there want to lend me theres that would be sweet too.
Thanks,
Andrew
https://www.sau.com.au/forums/topic/171284-standard-rear-muffler/
hey bro i can help ya, ive got one from a 33 full stock rear muffler with the curved connection that goes to exhaust (stock) ive also got a epa ive gota get off in a few weeks, do ya a deal ill lend you the muffler and if ur putting ur stock setup back on for epa. And ill borrow off ya from after the cat back exhaust in like amonth
if ur after that muffler thing with the twin tips...i got one its jus been chopped of with a bit of pipe out the other end..will need some sort of modification or weld to fit onto the stock pipe..
cant really take it anywhere ... feel free to come pick it up FOR FREE..livin up northern suburbs melb..
its just taking up space..thought id need it ..that was 4 years ago..its jus sititn in the warehouse collecting dust
send a PM. cheers
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
