Dunno if anyone has read the Tiser yet but page 8 talks about an 18 y/o guy getting caught doin 200km/h in an 80 zone!
He tells the cops he was tired and "Didn't realise how fast he was goin"!!!
They have impounded his "1993 Nissan Skyline GTR"
Was in Melbourne but hey we don't need any extra attention thanks.... :blush:
https://www.sau.com.au/forums/topic/171306-advertiser-today/
  • Replies 82
Was in Melbourne but hey we don't need any extra attention thanks.... :thumbsup:
Yeh was with his gf apparently...must have been a hell of a HJ not to relise he is doin 200.
there's already a thread about this 'another teen sensation'
+1
there was an R32 GTR, dark red with black wheels, a P plater, kept teasing me for a drag on a busy Anzac hwy last sat night
im a drag queen myself, but not on a busy road
how do they (P plater) get insurance for a GTR i wonder
hope he gets his licence suspended for a very long time....
the problem is this doesn't stop idiots from driving.
there was a thing on the radio about a guy down at Christies being caught for drink driving for the 17th time, and he was driving with out a license. There really is no way to keep idiots off the road, short of locking them up, and i don't want to pay more taxes to keep em in the slammer :thumbsup:
how is he luckly not to be dead? He could of been going 80 and went into the back of a ute and lost his head on some timber. Fact is speed has never killed anyone (apart from the drug) people are going to continue to speed so some of you saying it's making it harder for the rest of you must be dulisional. I've riden a motorcycle at nearly that speed plus 80 clicks and i'm not dead.
If you beleive "speed kills" like the government would have us believe you are a fool.
Who cares he got caught now hes gonna pay for it.
And now you say "ohh he could of hurt someone" well no shit but he didn't so who cares? he could kill someone at 80 just as well as he could at 200.
^^^^Well if he had happend to have hurt a family member of mine then he'd know about it! How can you say ""ohh he could of hurt someone" well no shit but he didn't so who cares?" and if he did! You for one on a bike would stand NO chance! Good luck to you!!
he could kill a member of your familly at 40k's.
If everyone pushed there cars everywhere people would still die.
I agree he deserves to be has his license suspened and car impounded. But you are going to live you life by "what if's" your gonna have a pretty boring life.
The way some of you guys drive in the hills is just as bad as what this kid did. Same oed for myself on my motorbike in the hills.
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
