Bloody hell, are we back to "pitching tents" again. I got to admit, I'm alittle afraid that Fatz
will do a better time in the Getz than I will in the Zed................ :blink:
so you're going to this one Wayne? you lucky bugger :O
  • Replies 263
Posted Images
Steve - Snowy is at dutton...
PI is only about an hour away from our places out south east... so we can drive. But for a 2 day event could hire out a holiday house.... They've done it before....
That sounds cool
Cheers :O
just camp on the island with the other penguins you softy. ;) fatz will keep you warm if need be.
I think he'll be sleeping with someone regardless of if they're cold or not :blink:
OMG its rhys all the piss heads are in this thread. hows the datto going?
"Datto" and "going" do not belong in the same sentence Druncan.
Now that Fatman is a fellow mountain goat, i've been busily practicing my drink driving and am in the midst of a heavy training regime for PI.
Entry Form and Sup Req's for this event are now available :blink: I've also put a link into the 1st post.
Click Here
Saturday is $130 (entries recieved before 12th Oct) and $135 for Sunday.
Looking forwards to seeing you all there. Once you have confirmed your entry we can look into the accommodation side of things.
Cheers
Snowy.
Entry Form and Sup Req's for this event are now available :thumbsup: I've also put a link into the 1st post.
Click Here
Cheers
Snowy.
If I was to skip a TopGear round up here in early November I could come down for a go at Phillip Island. Any problems with a Toyota giving you nissan boys a run? :down:
Being a Toyota is no problem. The colour though, expect some grief after ppl have consumed too many beers :thumbsup:
Thats ok, I have thick skin. I mean the car runs Holden, Ford and Nissan parts on it so clearly I have no shame...
Anyone hear of a big off on saturday at the AROCA sprints?
Someone has told me a Silver R34 GT-R went off and it was big. A write-off I believe.
Hope they are OK. ;)
Andrew
Edited by BBGTR
Someone has told me a Silver R34 GT-R went off and it was big. A right-off I believe.
Andrew
I know that Neil Provis-Vincent (provo on the forums) goes to the AROCA sprints, he has a siver R34GTR, hopefully it wasn't him aswell.....
Oh no lads.... someone's had an off big time on Saturday. Turn 8 I've been told. Snowy, when I first saw the pic I thought OMG, it's Snowy, but now I can see it's silver/grey not blue. Doesn't make it any better, but at least I was told everyone's fine.
Here's a pic I was sent......
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
