79 dolla plane flight and 135 car hire uncle dunk
you know you want to enter the challenge!!!!!!!!!!
im rusty so you should beat me good!
Hrm... even i could participate in this event as my Thailand trip is the weekend before... so i'll definitely be in town :sorcerer:
And seeing as though i wont have a decent car, might aswell get a sh|t bucket!
We could almost have a whole FIELD of GETZ :laughing-smiley-014:
  • Replies 263
Posted Images
lol. lend steve the trailer at your own risk! I remember some nasty trailer incidents that nathan weisel is still trying to forget!!! teehee.
actually I'd say the same thing about you fatz. in fact, lend fatz ANYTHING at your own risk.
n1 i have a trailer i wont be using for a resonable price
eg beer
Done, what do you drink?
lol
EC security guards are either blind or deaf, maybe both. eg i borrow naths trailer, return it and chain it up, then some loser tries to tow it away while its still chained to the fence - i hope that moron wrecked his towbar in the process. I hate thieves!!!
tacker did you need CAMS approval to get the FIA license? Higher level of license should be fine but I would still ring first lol
Duncan,
yep had to get a letter of no objection from CAMS sent to the local ASN before i could get it though.
How does the accom work down there snowy?
Same as deca with a caravan park and drive to the circuit?
just camp on the island with the other penguins you softy. :pwned: fatz will keep you warm if need be.
just camp on the island with the other penguins you softy. :( fatz will keep you warm if need be.
Bloody hell, are we back to "pitching tents" again. I got to admit, I'm alittle afraid that Fatz
will do a better time in the Getz than I will in the Zed................ :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
