  • Replies 56
i just got a carbon one. Dont glass ones warp and go rippley like some cheap bodykits do? Everytime ive seen a fibre glass one it has looked rippley to me. The carbon one has a PERFECT smooth finish, and you can paint it or leave it black.
How much do glass ones weigh? i havent weighed mine, but its hell light to pick up. Like ricknizmo, i like the look of the vents more than the weight saving.
Guest INASNT
Originally posted by Blitz
The bonnets UAS sells are very well finished, and the vents do look cool.
INASNT: why the hell would you let someone sit on your bonnet regardless of wether its cabon or not!
some stupid **** might sit on your bonnet when its parked in a carpark or instance. If alot of people are standing around talking sometimes peoples brains go to sleep and they decide to take a rest and sit on your bonnet.
yeah got mine from UAS. They dont budge on price tho! A while back i offered to buy a full GTR kit and carbon bonnet, the works, was gonna spend around 3 grand cash, and they wouldnt give me even a little discount! i think that sucks, there is always room for discount esp with cash. "The price on the website is the price." the dude told me...
  • 3 weeks later...
  • 1 year later...
Carbon Fibre (CF) top lining with Fibre Glass (FG) bonnets are supposed to be cheaper. Try not to pay over 800 for one.
I sell those on Hondas for only 500 OEM and 550 vented :P
A full 100% 3K grade CF will set you back above 1K
Carbon Kevlar is different realms and is also above 1K
Attached is pictures of the end product of a Celica 00-02 and a nearly ending product of an EG 4 door vented bonnet.
Apart from being light, the vents "are supposed" to improve air circulation by allowing heat from the heads to dissipitate efficiently, therefore maybe explaining the use of vents for Evos. But dont quote me on that, as I have no credible sources for the info on vents.
don't either of them decapitate the driver and passenger because they don't fold properly like metal bonnets in accident?
Yeah cause the metal bonnets are designed to crumble. Therefore carbon fiber bonnets are not ARD compliant.
How about we get a few picks and put some Homer Simpson "speed holes" on the car?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
