Yes ... Bonnets other than your factory ones are not approved. Reasons being they shatter during accidents, causing sharpnel type of injuries, crumple/bend zone is not there.
But there are some who swear by their CF bonnets that the 100% CF are actually much more tougher than factory OEM bonnets. This is really yet proven and documented.
Just my .5cts worth =)
  • Replies 56
Guest RedLineGTR
Thought that was true myself!!! but i doubt trying to explain it to the police :P
Guest RedLineGTR
hahahaa ... the prices on the website - $3,700.00 a pop for the dry CF bonnets
ermmm .... I think i would be better of getting a generic wet CF bonnet from Taiwan and use the rest of the money for a holiday or some other mods.
heehee
hahahaah lolz :P But in professional racing in Japan a bonnet that would weigh 2.2kg would be beneficial for track racing etc. Not that i would spend that much myself :(
OEM bonnets are designed to be part of the crumple zone which spreads an impact longer over time reducing the force on the passengers.
If the bonnet is weaker, it weakens the crumple zone.
If the bonnet is stronger, it wont crumple and will go through the windscreen taking your heads off with it.
I dont see the point really but thats just me. I dont have a purple atmo venting BOV either so I guess you can tell where I am coming from.
OEM bonnets are designed to be part of the crumple zone which speads an impact longer over time reducing the force on the passengers.
yes ya right. It all depends on each perspective and how ricey they wish their rides to be. No offense to those with such bonnets, because I also have the bonnet for my own and selling them too!!
Rice or not rice, I guess its also considered an art, just like drifting. you might be surprised at how artistic ricey some cars worldwide can grab your attention and leave you lingering with thoughts ... heheheheeee
my .5cts worth :P
well said. Also I've seen a few carbon fibre bonnets that don't have hinge locks/catches (can't think of their proper name). when the bonnnet is closed on most cars there is a small metal piece that sticks up into the bonnet next to the hinge mounts, if the car is in an accident they prevent the bonnet from flying back through the windscreen if the hinges fail.
some carbon fibre bonnets don't have the right holes in the underbonnnet frame work, so the catches don't do their job properly.
also, if your only after them for the wank factor I think supercheap and roughtobarn sell rolls of stick on carbon look plastic sheets like contact. :headspin: :wassup:
picked up a fibreglass bonnet today vented for $740. carbon fibre one was $1200, but its essentially just a fibreglass one with 3 carbon fibre skin layers... so its not really worth the extra $500 or so... so yeah... i guess you save on painting and thats it!!!
OMG ... FG going for 740!? With additional CF linings going for 1.2 large!? What car are your driving? R33??
This has been done a million and one times guys.......those bonnets are 1 layer c/f with the rest chopped strad and a plastic inner frame laminated on the inside.....In my opinion they are poorly laminated and dont offer ANY structural support what so ever......the genuine c/f bonnets from high class company's do what there made to do....and that is be extremly strong and very light....not just for looks.....and to those who say there not strong....what about a 34 GTR V spec II bonnet?There standard issue!Not to mention its commonly used on many supercars such as lambo's and ferrari....
I agree with Troy.
If you want one for looks, go for it, but don't kid yourself you are getting the benefits of C/F without dropping some serious coin.
I have spoken to the RTA signatories about C/F panels and bonnets. Yes they are illegal (unless factory fitted, obviously) and will require engineering (in NSW anyway).
Lucien.
bonnet pin or hood pins?
I dunno if your post was in response to my post, but seeing as it was straight after I'll assume it was....
I wasn't talking about anything at the front of the bonnet , but at the back where it's hinged. theres a small bit of metal on each side, next to the hinges which hooks into the bonnet framework.(on alot, but not all cars)
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
