OK, I'm a bit on the drunk side, so bear with me. After about 15min of solid debating. No one between my buddies and I can descide on the reasoning behind the fact that the brake pedal in automatic cars, is more than twice the size of the pedal in manual transmission cars. It seems to me they could have easily just added a larger foot rest, or maybe a place to hide a firearm. Instead they just made the pedal really damn big. Hopefully someone can tell me why the pedal is so large.
Also, as long as were at it. Im curious to see what peoples ideas are as to something we could put in the spot where the clutch normally is, instead of just making the brake pedal larger. I personally think a toaster, and a place for butter and/or jelly would be an excellent thing to put there.
Edited by Rabid
  • Replies 47
Your drunk at 5.55pm on a Monday night, then come on here asking that question?
Anyway, good question. Google has NOTHING. What I find funny is when the pedal has 'brake' writen across it. So maybe thats it. It wouldnt fit on a manual sized pedal.
But I think auto pedals should be even size. So like the accelerator is as big as the brake. So they can both be bigger.
It's so grandma always knows where to stomp in case of emergency.
LMAO On that note, an old lady today almost got herself killed today, i was turning right and she was pulling away from the kerb and instead of accelerating to get out of my way, she hit the brake and i almost went into her door. We seriously need some kind of basic crash avoidance course because people have no f**king idea what to do in emergencies. I have a mate who pulled his handbrake at 90km/h because his car stalled and he had no brakes, he paniced, pulled it really hard and ended up in a pole. Ive done a driving course, next on my list is CAMS license :thumbsup: man i cant wait!
How about this answer:
The brake pedal gets used more in automatic cars - therefore larger pedal to prevent it wearing out?
In manual cars most people gear down instead of braking hence less wear on the pedal, therefore smaller pedal.
makes sense to me :thumbsup:
haha that reminds me of my old school caretaker's buggy thing. it had two pedals too. a big green one that said GO and a big red one that said STOP.
maybe the pedal is bigger because us auto drivers have bigger feet. and you know what they say bout big feet.... :thumbsup:
I'm east coast, United States. It was more like 3 or 4am for me, on Sunday night.
Large shoes?
I still think there should be a toaster in that spot instead. I can't tell you how many times I have been driving, thinking to myself "I could really go for some toast right now.. or a pop tart.. or toaster strudel", only to be disappointed by the fact that I have a clutch pedal instead of a toaster. Dodgey engineering for sure.
They made it that big so you can put both feet on the pedal, it's called toe toe braking, only the best racing drivers use this method.
I thought when you put both feet on it, it was called 'OHH SHIT!!' braking..
A wider brake pedal would make it easier to left foot brake, as you don't have to put your two feet as close together and possibly foul each other.
Not saying its the reason, just suggesting it as a reason.
Has anyone driven some of the newer auto's that has a foot brake instead of a handbrake? For those that don't know about it, they install this foot brake/pedal exactly where the clutch is on a manual car.
Has anyone subconsciously tried to clutch an auto and hit this foot brake before?
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
