Has anyone driven some of the newer auto's that has a foot brake instead of a handbrake? For those that don't know about it, they install this foot brake/pedal exactly where the clutch is on a manual car.
Has anyone subconsciously tried to clutch an auto and hit this foot brake before?
they have been doing that for years.
imagine trying to do handbrake turns in the old kingswoods that had the handbrake in between the drivers seat and the door.
also bring back the old highbeam switch next to the clutch pedal i saw.
  • Replies 47
i think the big fat pedal is for - as said so that you can plant both feet on it in an emergency. or so that you have more of a pedal to hit when braking? maybe some people miss it????
and the foot brake instead of a handbrake is just stupid... cant pull it when driving, and you cant rest yuor feet where it is
No clutch = more room + small brake pedal = more chance of missing = increase size of brake pedal = higher chance of hitting the brake pedal than thin air
Or could just be that auto drivers arent as coordinated as manual drivers therefore requiring larger brake pedal XD
the merc courtesy car i had from gt auto, had the accelerator pedal, the big brake pedal, and the handbrake pedal next to the brake pedal. Luckily, because im a n00b with german automobiles, wayne made sure i knew about the hand brake pedal that was situated where the clutch pedal would normally be situated.
hate to think what i would have gotten myself into if I thought that perhaps the merc had a tiptronic that works off the 3rd pedal!
I would rather have a massive pedal I cant miss in an emergency ( cause its so freakin big ) rather than have a smaller pedal and a toaster to electrocute me when accidentally stick my foot in it during an emergency stop !
my ol torry used to have the "hand" brake left side next to the main brake with a switch left of the console you had to "twist and pull"
of coarse the car started as a column shift auto, became a t-bar auto then a 4 sp manual. ahhhh the ol steel thing was great... doors 4" thick.. choice wood grain coloir plastics with the lino covered foam infils.. pure class
did burnouts well though with its leaf springs. major braking upgrade went from rear drums to 4 wheel disks .. awsome.
that thing chewed more blocks then any other car I've ever owned to this day.. it was the variable capacity car.. it had as much capacity as I could afford at the next time I blew something...
Edited by scheris
i suppose that in a manual car when you have to stop in a hurry you put your left foot on the clutch as well as your right foot on the brake, so you left foot stops your right foot over shooting. so with left leg out wide, you need a bigger brake pedal to help you hit the target better.
my guess at why the auto brake pedal is so big is so you can left foot brake (and i'm being serious).
That isnt it...
I honestly think if google didnt have an answer, there is no reason to it other than the ' 'cause I can' logic.
It IS so you can brake with either foot
Prove it. Because deadset that is one of the most dangerous things in an emergency as 99.99% of people just push down hard with both feet. So if one is on the go, and the other is on the woah, and you punch them both, you do not stop. (most people are smart enough to not use their left foot in an auto car so it isnt an issue).
And if car designers really ARE that stupid, probably not a bad idea they make the thing tiny.
Left foot braking is a pretty contentious issue. Most of the oldschool guys don't like it, but a lot of the modern advanced driving instructors have no problem with it.
To my knowledge, a lot of the professional racers with clutchless manual setups will always left foot brake these days, and even in clutch-equipped cars some racers will left foot trail brake, or use it to adjust the car's attitude.
I don't see how its "not smart" to left foot brake in an auto, as long as you know what you're doing (which, of course, does rule out the vast majority of road users). I find left foot braking my old man's auto car quite helpful when I'm going for a spirited drive in it, and I will occasionally dab the left foot in my manual car to tuck the nose in when its power-on understeering, but if I ever were to panic stop I'll instinctively right foot brake in either car.
every go-kart driver left foot brakes. i'd like to see someone use the 1 foot for braking and accelerating in a go-kart.
as scathing said, race drivers who left foot brake can get on the gas earlier, and keep the car stable through corners. it also helps to catch the car if you lock the rear brakes. greg murphy is probably the most notable of the v8 supercar drivers who left foot brake.
the new mitsubishi colts have the pedal for the handbrake. its really odd i reckon. When i did
work experience at yorke mitsubishi (Adelaide) heaps of new colts were getting their hand brake cables and rear pads fitted with new ones because people were forgetting about the hand brake because it was a foot pedal and not the usual hand lever thingo. lol i thought it was funny, ccould of been a scheme by mistubishi to make people spend more money on changing rear pads and handbrake cables because they knew people would forget about the hand/foot brake pedal lol
People that drive auto's are crappy drivers and manufactures design them larger to give them all the help they can.
Nah, seriously I think it's that auto's used to be classified as luxury and only higher end cars had them and the bigger pedal signified the refinement and added benefit.
abviously you dont get how unbelievably convenient it would be to have a toaster in your car :woot:
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
