I recently cleaned my out while i was putting on a new bumper.
I just used a can engine decreaser (<$3NZ).
Then used detergent, followed by a very good rinse.
And finally a rinse with meths.
Although it looked clean(ish) when i first looked into it, alot black stuff came out.
But i guess it wasnt too bad considering it hasnt been cleaned for 13yrs.
And yeah, can you let us know how well it fits, as i m also looking at upgrading to an R34 SMIC.
it fited perfectly for me. its longer in height so the inner guard doesnt go in like it should, but it still goes in.
mmmmmmmmmm....R34 IC into R33...sounds like a nice little upgrade!
Wouldn't mind learning a little more about this.....along with expected/real outcomes???
Regards,
Superspit.
Be careful with degreaser.. Some eats alum.
I use petrol. I seal up one end with a few plastic freezer bags + a few rubber bands. Pour the petrol in one end.. shake it around a little and repeat the process until the petrol comes out clean.
You can use shellite to clean it out as it evaporates and will leave no residue.
Shelite is some real nasty shit. Had a nasty experience with shelite.
I just don't get what makes that stuff so potent. I haven't researched the chemical structure etc, i'm not that desparate to know. haha. I mean sure, you can light petrol, kero etc on fire. They burn very easily, and they're dangerous. But shelite. Man. I had a friend try and start one of those wood barbies at the natio park using shelite. He thought it would be like petty. covered the wood in shelit, and lit it using a match. Man, wasn't pretty.
So does shelite not leave residue? petrol must be ok, considering the car eats it normally. that's why I use it anyways.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
