hey guys just wondering to do this conversion, what extra is needed? i understand that the diff center, half shaft's is needed? what extra? and how does it all bolt? i.e any dodgy mods needed? do the gtst hubs accept the gtr drive shafts? my diff open wheeled once and i wana sort this out before it gets worse. cheers
https://www.sau.com.au/forums/topic/171411-gtr-diff-into-gtst-r32/
Not possible..
However, there is a gtr style/mech center around for the R32/S13 pumpkin that runs the gtst/s13 spline count.
There's 2 different types as far as I'm aware. The standard GTR style with a soft engagement and what is often referred to as a nismo center with more clutch packs and shallower ramps that provide a quicker lock.
The later nismo is the one to get.
Another option that 'may' be possible is to use an 87-89 300zx long nose r200 lsd center in your short nose. They 'Apparently' they bolt in to the short nose housing without issues. I haven't done it myself so I don't know first hand.
  • 3 weeks later...
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • Yea pedal box and no abs
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
