Airflow Meter
Ben101
 Share
Hey pplz,
My r32 gts-t doesn't always seem start without me having to give it some gas
as it stands its stock apart from a cat back and a walbro fuel pump i've done some searching on
the forum, and everything I read seams to point to the air flow meter
the starting problem, the car been jerky when you lift off then go to
accelerate again, would the Z32 upgrade be a wise move as for furture mods, am
I to belive that the stock computer will handle it no worries?
Cheers
Stock ECU will not run a Z32 without a remap
clean it, resolder it (gtr AFm repair thread in DIY) or get a second hand one.
by 'remap' would be alright if u have a SAFC? or do u need a pfc?
Edited by ztuned
Cheers guys I'll look into the gtr thread
Hey craved you still got your ninja, back in 2005 I had problems with
mine and you were giving me some suggestion?
yes mate still got it, just been resprayed and the front forks rebuilt.
havent ridden it in over 6 months though due to the work on it, but its almost put back together.
Shouldn't need to touch accelerator to start it.
You will need to check the throttle position sensor is set correctly and working, especially idle position, check the coolant temp sensor if you think its lacking enrichment, check the base idle, check for vac leaks and maybe clean/service the air regulator.
After fixing that it should start at the touch of the key first time, every time.
Also try priming the pump for a few secs before start, see if it helps, this could point to a faulty check valve in the pump if it starts after the rail is primed with pressure.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
