Had a good time watching all the cars ... was wondering what some peoples results were ... the best i can remember was most skylines getting 13's ... martin soarer doing low 13's ... an old school skyline doing 15's (about 45 times too i might add :P ) ... and excel in the low 13's ( i wonder whats under the bonnet??) ... that red rotary drag car doing a 9 something and made me deaf ... keirs 32gtr with a 10.42? also made me deaf ... lots of commies in the 13's 14's ... falcon with a 12.9?? oh yeah ... evos with low 13's and 180's in high 12's??
correct me if im wrong ..
https://www.sau.com.au/forums/topic/17154-drag-results/
Very nice times there man! It certainly looked the goods.
The whole car was twisting and rocking at the 1st/2nd gearchanges - I was sure something was bound to snap with all that force/grunt! What mods do you have? Did you import the car yourself or is it local realease? (not sure if they sold them here or not).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355002
my friend with me has an evo4 ... he didn't race it and it was parked outside with next to my car ... it used to be 224kw@all 4 ... that was with a hks turbo ... and motec computer tuned by rpm ... he never races his car though ... hes since taken out the big turbo and made everything stock agian ... lookin to sell this evo4
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355087
Good to see everyone out and finally put some faces to names.
I did 13 passes and my clutch didn't even stink on the way home!! Even though the commentator (Andrew I think) thought I was trying to fry it, with so many runs in a row.
The track was bloody slippery at first but good to see some nice rubber laid down throughout the day. I finally broke into the 12.4's running 15PSI with a 12.421 at 110.26MPH (60' 1.835sec).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355619
Great day, thanks Ivan & crew from RPM. First time I've ever done it and was good to drive home OK (apart from a now leaking exhaust manifold that I'm told is no big deal for a while!).
13.42 ET, 106.5mph, best 60' was 2.11s.
Main thing is that I beat grepin, Chris32 and Bugalugs :burnout: Dare I say quickest GTS-T on the day! Bugalugs' run were amazing though, 13.44 I think and 106.99mph!! And that's with a stock ECU...good stuff.
grepin, do you now surender? Do we declare WW1 has been won by Freebaggin .... or should we wait until after the climactic battle this Sat at Tilbrooks for the outcome of WW1?
Then WW2 starts soon after!
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355737
    • I can also smell fuel in oil if that helps.
    • Hello, after engine rebuild(new cylinder liners and piston rings, arp headstuds, metal cometic tripple layer gasket, all new main/rod bearings) and roughly 100km made I did measure compression and it’s (1-6) - 80, 60, 90, 120, 110, 135. It’s rb25det series 1 - hydraulic lifters. Measured on cold engine. Didn’t check on hot due to overall car problems such as broken 3rd gear, idle issues, misfire etc. I did smoke test only on 2nd and 5th cylinder bcs soldering iron used with this method broke itself. So after setting cams to side - side 90 left/right angle I can see smoke coming off from intake manifold and turbo exhaust flange. 5th didn’t notice any smoke. Shop did head, valve etc job but I assemble it by myself. So I thinking about lifters. I don’t remember if they were soft or not it was long time ago. In my opinion I didn’t bleed them and they can be opened more than they should be. Can it be more likely possible? Or timing can be off by 1 teeth and can cause such weird compression? But if timing would be out wouldn’t it be like such big difference across all cylinders? Please help I’m so sad it happened.
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
