Hi All,
Just wanting some help. I've started buying bits and pieces of Audio gear for my R34, and I have bought a good speaker amp and have bought some 6.5" splits to go into the doors.
I am keen on a bit of a DIY job. I would be happy to pay a pro money, but i want to give it a shot myself. I have a bit of electrical experience so wiring isn't a problem. Its just I have absolutely no idea where to fit the stuff. Even though it is a pretty small amp (kicker kx200.2) it wont fit underneath either of the front seats. I had (what I thought) to be an ingenious idea to mount the amp on the back of the drives side front seat, where it is pretty much hidden inside the pocket. running the wires down to the floor would be an easy job and they would be hidden by the plastic knee board on the back of the seat. but I have been told by people that it wouldn't be enough cooling for the amp to sit inside the pocket. Any advice/feedback on this idea would be sweet.
Also, there are a few funny clips on the doors. When/if I attempt the speaker install, what are the best way to take these out as I would be pissed if I frigged up the interior!!
Many Thanks,
Steve
p.s. see attached photo :P
https://www.sau.com.au/forums/topic/171546-amp-mounting-in-r34gtt-2dr/
why???? you run more risk of it burning up, more risk of it getting pinched , more risk of destroy cables. put it int h rear behind the rear seat. trav you suprise me sometimes...
Surprise? Have you ever seen me pull a cat out a hat?!
U would have to make some sort of moulding for it behind the rear seat. Do not just screw it into the "wall" behind the rear seat as thats where the fuel tank is. I screwed mine down in the boot floor on the passangers side. Not pretty but works fine.
thanks guys for your responses,
For an update,
My plan was to buy a sub and mono amp, and have all of that installed nicely in the boot, keeping all the speakers etc, toward the front, just leaving the sub stuff in the boot. that was my plan. But if the ol' back of the back (on mdf) seat is the answer, then so be it. But keep me posted on any other ideas you may have.
Cheers!
what about underneath the rear seat? is there any roon?
Hey mate to remove the door panels the funny clips you push the centre in and pull the whole plug out :) dont forget to remove everything off the door and lift it up and off then unclip the power window thingo and poof its off..
now for your amp setup ..
just a small idea i came up with .. not really happy with it but you never are reaLLY - dont over heat and doesnt move and looks ok what more do u want
I plan to get new cables and new sheath to cover the other cables in chrome/silver just to match the alpine and fusion amp.. and then the boot will go red/black with a sub in the spare tyre hole (inverted)
Edited by DECIM8
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
