Ok, I posted this in members section but everyone's entering their cars!
So Im hopefully going to enter both my cars in the S n S - cause I can
Now - Im going to drive my 33 there cause I dont trust anyone else but my 31 needs a driver.
My old man will be in hospital on the following day so he cant do it (needs a day of rest apparantly on the sunday, soft! )
So anyone over 25 (I'll consider under 25 due to insurance) around Hornsby and is going to s n s
for the whole day - wanna drive my car if you arent entering?
I'll let you do a burnout! :P
https://www.sau.com.au/forums/topic/171552-i-need-a-favour-show-and-shine/
I'll let you do a burnout! :)
In for the burnout :) , got to have a chat with the coasties on thurs to find out their plan of attack is, as I was asked to drive Kasey's line. I can let you know on friday or maybe find you a stuntdriver. :)
mate how bout u find 2 drivers so that 33 can be driven like it was supposed to.....
hahahaha
who looped it at the autosports skid pan day and who didnt??
me - 0
you - 11ty billion ;)
hahahaha
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
