Track Day, Symonds Plains...
Guest RB MaNiAc
im tassie mod for AE86DC & part of my job is to organise track days/cruise's so here it is, you guys are more than welcome to come along if u want.
Track Day
When: Saturday 7th of July
Meeting place: Southern Guys: Granton Car Park(next to brighton memorial hall) @ 8:30am...Northern Guys: meet us at Symonds Plains @ 10:30am
Time: 10:30am
Route and Destination: midlands highway, Symonds Plains...
Cost: $99.00
Rules: NO Burnouts, NO Drifting, No Donuts. u get the picture, GRIP ONLY bitches & ur normal saftey gear such as a helmet
it will be up to you to organise ur own food "n" sh*t
cheers
Andrew :P
Edited by RB MaNiAc
https://www.sau.com.au/forums/topic/171557-track-day-symonds-plains/
any of you guys considering gong to this??
cheers
Andrew :P
If car is running by then maybe, although it does clash with the Red Nose day Cruise!!!
Oh and the fact that there will be a SAU track day soon ;)
am I missing something, going to what? :mellow:
He means the Yota track day Dom :mellow:
Who are Yota? Is it at the Domain? :P
Yoto, car club maybe ??????????
Its at Symonds
Track Day
When: Saturday 30th of June[/b]
Meeting place: Southern Guys: Granton Car Park(next to brighton memorial hall) @ 8:30am...Northern Guys: meet us at Symonds Plains @ 10:30am[/size]
Edited by woolls
  • 3 weeks later...
so is this trackday still going ahead on the 7th july, what time? how much?
yeh this is still going ahead, meeting at symonds plains at 10:30am...details on this are provided in the 1st post...$55 if you are a member of a cams affiliated car club, if ur not the cost is $99.
It is only $55.00 if you are a member of a Motorsports Tasmania affiliated car club. I'm not sure who they all are, I know the LCCT are. NWCC are not, there's a couple down south that are.
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
